Volvoman37 Posted January 28, 2005 Report Share Posted January 28, 2005 alright, i finally have all my stuff together for my car, and i just wanna verify my info so i dont screw anything up that could be avoided.would i run the ANT. REMOTE(from the HU) wire to the POWER CONTROL(on the amp) and the AMP REMOTE(HU) to the EXT. AMP CONTROL(amp)?? Link to comment Share on other sites More sharing options...
BenW Posted January 28, 2005 Report Share Posted January 28, 2005 The amp remote off of the Head unit SHOULD do to a Remote or Control INput on the Amp.I dont know what that "ext amp control" is.. Link to comment Share on other sites More sharing options...
PyROZen Posted January 28, 2005 Report Share Posted January 28, 2005 ext amp control is probably a separate remote you can buy so you can control your gain and freq cutoff from inside the car. I would leave that wire alone and just connect the HU remote wire to the amp remote wire like Ben said.edit, btw you shouldn't have to use the ANT REMOTE either. There is usually 1 or 2 wires you don't need whenever you hook up a wiring harness. Link to comment Share on other sites More sharing options...
Volvoman37 Posted January 28, 2005 Author Report Share Posted January 28, 2005 so just the amp remote to amp control? or amp remote to power control? Link to comment Share on other sites More sharing options...
theunderlord Posted January 28, 2005 Report Share Posted January 28, 2005 so just the amp remote to amp control? or amp remote to power control?←splice the remote turn on lead from HU to amp remote. :) Link to comment Share on other sites More sharing options...
PyROZen Posted January 28, 2005 Report Share Posted January 28, 2005 splice the remote turn on lead from HU to amp remote. ←^ what he said ^though im guessing on your amp, the remote wire is called the power control. just try both ways if it still won't work. the HU turn on wire is low voltage like 5v, so you can't fry anything with it. You HU Remote turn on wire should be Blue-White Link to comment Share on other sites More sharing options...
bogelo Posted January 29, 2005 Report Share Posted January 29, 2005 alright, i finally have all my stuff together for my car, and i just wanna verify my info so i dont screw anything up that could be avoided.would i run the ANT. REMOTE(from the HU) wire to the POWER CONTROL(on the amp) and the AMP REMOTE(HU) to the EXT. AMP CONTROL(amp)??←You can use ANT. REMOTE (from HU) or AMP REMOTE (from HU) to the AMP REMOTE (AMP).Basically Amplifier has 3 connections, one to the positive lead +12v, one negative lead -12v (marked as ground, GND), and one amplifier remote control (REM, usually in the middle between +12v and -12v).Amp Connection 101:+12v = straight from the battery-12v = straight from the car' bodyREM = straight from the HU' ANT remote or HU' amp remote Link to comment Share on other sites More sharing options...
