Malvasi Posted November 5, 2012 Report Share Posted November 5, 2012 Hi guys, I am putting a yellow top in my 850 and the negative cables don't reach the terminal. Does anyone happen to know the lengths? I want make the cables at work and wonder if anyone else has had this issue and just replaced the cables? Thanks, Link to comment Share on other sites More sharing options...
Malvasi Posted November 6, 2012 Author Report Share Posted November 6, 2012 Nobody has replaced these? I have searched both here and MVS and couldn't find the info... I guess I will just take them out tonight and then cut new ones tomorrow. Thanks guys and please feel free to chime in if you have info. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted November 6, 2012 Report Share Posted November 6, 2012 There is a strap that holds them to the battery tray. Loosen it and they will reach. At worst you may need to change the terminals. Link to comment Share on other sites More sharing options...
Oreo931 Posted November 6, 2012 Report Share Posted November 6, 2012 Hi guys, I am putting a yellow top in my 850 and the negative cables don't reach the terminal. Does anyone happen to know the lengths? I want make the cables at work and wonder if anyone else has had this issue and just replaced the cables? Thanks, Not sure of the lengths off the top of my head, but it's really easy if you remove one cable, measure it, and then just cut the new cable to the correct length. They aren't super long. Buy a couple extra feet of cable just to be sure you have enough. Link to comment Share on other sites More sharing options...
survolvo Posted November 6, 2012 Report Share Posted November 6, 2012 Not too hard to figure out. Grab the current cable, and measure how much more you need. Buy a cable that length. Link to comment Share on other sites More sharing options...
Malvasi Posted November 13, 2012 Author Report Share Posted November 13, 2012 There is a strap that holds them to the battery tray. Loosen it and they will reach. At worst you may need to change the terminals. Yeah mine was already released from that and the ground just wouldn't reach, and this is with adding new terminals, I went with two new Stingers that allow for two 0-4 gauge inputs. Not too hard to figure out. Grab the current cable, and measure how much more you need. Buy a cable that length. I knew that, I was hoping to get the info so I could get the cables cut and done before tearing it apart. Link to comment Share on other sites More sharing options...
