atefitty Posted December 11, 2012 Report Share Posted December 11, 2012 My fuel pump seems to be tired and cutting out..What are your guys opinions on IPD's aftermarket one? the sell an OEM one but it's nearly $400..they also sell Bosch pumps you can fit into your old assembly..I'd rather not bother cutting and splicing though. Thanks. Link to comment Share on other sites More sharing options...
Keaton85 Posted December 11, 2012 Report Share Posted December 11, 2012 Are you sure it's not the fuel pump relay? Also the walbro inserts are the way to go. IPD is probably the most expensive source though. Link to comment Share on other sites More sharing options...
cn90 Posted December 11, 2012 Report Share Posted December 11, 2012 atefifty, How many miles when your fuel pump went bad? 1. Below is Fuel Relay troubleshooting that I wrote. The bottom line is jump 15 + 87, if car runs, then relay is bad. You can actually check the well-being of the fuel pump via the relay socket using an Ohmmeter. See Step #5, the fuel pump should have 1.0-1.5 Ohm. All is included here: http://www.matthewsvolvosite.com/forums/viewtopic.php?t=52252 2. rmeuropean.com now carries Walbro for $61: http://www.rmeuropean.com/Part-Number/Fuel-Pump-Kit-(Walbro-Version)-(In-Tank)-__300710606_WAL_D821D26B.aspx Link to comment Share on other sites More sharing options...
atefitty Posted December 11, 2012 Author Report Share Posted December 11, 2012 Are you sure it's not the fuel pump relay? Also the walbro inserts are the way to go. IPD is probably the most expensive source though. Yes, It could be the relay but I have 174K now and I'm actually wanting to do both so I know everything is replaced. Link to comment Share on other sites More sharing options...
Keaton85 Posted December 11, 2012 Report Share Posted December 11, 2012 File pumps could go 300k... Why botherFuel* Link to comment Share on other sites More sharing options...
atefitty Posted December 11, 2012 Author Report Share Posted December 11, 2012 atefifty, How many miles when your fuel pump went bad? 1. Below is Fuel Relay troubleshooting that I wrote. The bottom line is jump 15 + 87, if car runs, then relay is bad. You can actually check the well-being of the fuel pump via the relay socket using an Ohmmeter. See Step #5, the fuel pump should have 1.0-1.5 Ohm. All is included here: http://www.___.com/forums/viewtopic.php?t=52252 2. rmeuropean.com now carries Walbro for $61: http://www.rmeuropean.com/Part-Number/Fuel-Pump-Kit-(Walbro-Version)-(In-Tank)-__300710606_WAL_D821D26B.aspx Good, I will test it as you suggest..Thanks .Drove to work today and it didn't act up at all.. Link to comment Share on other sites More sharing options...
atefitty Posted December 11, 2012 Author Report Share Posted December 11, 2012 Wow, just checked rmeuropean site..looks like they are the way to go..gonna get a relay from them too..sorry IPD...thanks cn90 Link to comment Share on other sites More sharing options...
Keaton85 Posted December 11, 2012 Report Share Posted December 11, 2012 If you can solder then the relays are extremely easy to rebuild. Also they can be tested... It sounds like its only the relay and not the pump. Although it spuds like you just want to replace things good or bad? Link to comment Share on other sites More sharing options...
atefitty Posted December 11, 2012 Author Report Share Posted December 11, 2012 I can't even solder two wires together without them coming apart Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted December 11, 2012 Report Share Posted December 11, 2012 FYI, I'm pretty sure there is a knock-off market for Walbros. May want to try and find out if the product you're buying is rumored to be a fake or not. And Keaton, you're claiming they can run 300k? I'm at 175k on my original and was thinking about replacing mine before it dies instead of when, because I thought I was entering the range, but if they run that long I think I'll just try and source some relays to keep in the trunk. Link to comment Share on other sites More sharing options...
cn90 Posted December 11, 2012 Report Share Posted December 11, 2012 FYI, I'm pretty sure there is a knock-off market for Walbros. May want to try and find out if the product you're buying is rumored to be a fake or not. And Keaton, you're claiming they can run 300k? I'm at 175k on my original and was thinking about replacing mine before it dies instead of when, because I thought I was entering the range, but if they run that long I think I'll just try and source some relays to keep in the trunk. No need for relay, just make a small jumper wire and store it in the glovebox. When needed, simply jump 15 and 87. See the DIY I posted above. At 175K, if you regularly travel out of town, I'd put in a good (non-fake) Walbro and call it a day. I hate getting stranded in the middle of nowhere. Fuel Pump is like spark plugs, they have their better days... After ___ miles, they go bye bye. Link to comment Share on other sites More sharing options...
