DAYWALKER Posted December 23, 2012 Author Report Share Posted December 23, 2012 update on my finding. just got done droping the oil pan. didn't see alot of metal shaving. i did see something but is very little. i think is normal wear and tear since i believe this is the first time the pan have been drop. i also check my rod but i didn't see any of them bent. is it possible that it is bent but i can't see it. i did spend half an hour just looking for any sign of contact on the block,piston skirt and wall. other thing im not too sure is when check the rod bearing. do you move it side to side toward side of the block and up and down. i have play when i move them side to side toward front of motor but i believe that is normal. can anybody confirm this for me. is it possible that i have a bad lifter? i'm really stump now. i was so sure it was either the rod or rod bearing. Link to comment Share on other sites More sharing options...
kateean2 Posted December 23, 2012 Report Share Posted December 23, 2012 Op how do you think this happened? Link to comment Share on other sites More sharing options...
DAYWALKER Posted December 23, 2012 Author Report Share Posted December 23, 2012 Op how do you think this happened? was boosting and have couple misfire and then a knock. probably detonation Link to comment Share on other sites More sharing options...
DAYWALKER Posted January 4, 2013 Author Report Share Posted January 4, 2013 i finally got my rod out and number one rod was a little bent. i was surprise it wasn't bent more due to the loud knocking noise. i guess it don't take much to get the motor out of balance. the bent rod is very hard to see even though it is remove from the block. i still don't get what is hitting in the cylinder wall to make that knock noise? i did inspect everything else but didn't see any other damage. any idea? Link to comment Share on other sites More sharing options...
Zappo Posted January 4, 2013 Report Share Posted January 4, 2013 It isn't hitting the cylinder wall at all. In fact, you probably have no damage to the cylinders or pistons. I can't remember where exactly it contacts, but examine the rod closely. Look for a part that seems to be machined. It isn't. Link to comment Share on other sites More sharing options...
