BoostedMoose517 Posted January 25, 2013 Report Share Posted January 25, 2013 My friend has been getting ahold of me for this car he did, He replaced the seal idk how many times but he says it keeps spitting the seal out, I never worked on one so I don't know if there is any special steps to this. Any help i would greatly appreciate it. Link to comment Share on other sites More sharing options...
S8ET6 Posted January 25, 2013 Report Share Posted January 25, 2013 Sounds like he needs to clean the PVC (Flame Trap) Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted January 25, 2013 Report Share Posted January 25, 2013 If the crankcase ventilation system (PCV) was clogged it would cause excessive crankcase pressure which would force the seal out and create a habitual leaking problem. However, it could have failed the first time due to age and subsequent times due to misinstallation. The best way to install the seal is to use an old seal as a drift and slowly work the seal in with a bit of lubricant (engine oil) on the outer edge. The seal must be flush against the mating surface. This is tough to do without a proper drift, however, an old seal works perfectly for this purpose. Link to comment Share on other sites More sharing options...
