VolvoRine Posted February 8, 2013 Report Share Posted February 8, 2013 I recently changed my water pump OEM (2 days ago) and did a timing belt (hydraulic tensioner) service too... when I filled up my car with water just to do a system test the car will not leak but it literally pours water from the back of the timing belt cover by the water pump, I'm thinking is the freeze plug on the block... how hard is it to change that without removing the engine off the car?? Any advice would be highly appreciate it! -Josh Link to comment Share on other sites More sharing options...
Commander Riker Posted February 8, 2013 Report Share Posted February 8, 2013 I'm just going to take a stab... but maybe the pump is seated properly or the gasket got folded? Link to comment Share on other sites More sharing options...
Brant Posted February 9, 2013 Report Share Posted February 9, 2013 What freeze plug? These blocks don't have freeze plugs. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted February 9, 2013 Report Share Posted February 9, 2013 this is the only pic i have from tearing down a motor for head gasket. the channels around the cylinder walls empty out into the water pump area. if the water pump is not seated right then the water will pour out of that area. Link to comment Share on other sites More sharing options...
Matty Moo Posted February 9, 2013 Report Share Posted February 9, 2013 I've changed 8 water pumps altogether, I haven't had a single old gasket come cleanly off. I've always had to scrape some of it off the block blindly while tearing up my arm. I'm guessing either of three things. 1. Some old gasket material was still on the block when he installed the new pump/gasket. 2. The gasket somehow got fubared/torn when he put it on. 3. The pump got hung up on the plastic that makes up the back part of the timing cover. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted February 9, 2013 Report Share Posted February 9, 2013 I've changed 8 water pumps altogether, I haven't had a single old gasket come cleanly off. I've always had to scrape some of it off the block blindly while tearing up my arm. I'm guessing either of three things. 1. Some old gasket material was still on the block when he installed the new pump/gasket. 2. The gasket somehow got fubared/torn when he put it on. 3. The pump got hung up on the plastic that makes up the back part of the timing cover. This. I would bet money you didnt get all the gasket off. Link to comment Share on other sites More sharing options...
VolvoRine Posted February 9, 2013 Author Report Share Posted February 9, 2013 I've changed 8 water pumps altogether, I haven't had a single old gasket come cleanly off. I've always had to scrape some of it off the block blindly while tearing up my arm. I'm guessing either of three things. 1. Some old gasket material was still on the block when he installed the new pump/gasket. 2. The gasket somehow got fubared/torn when he put it on. 3. The pump got hung up on the plastic that makes up the back part of the timing cover. Yup... I removed the lower timing belt cover and found out the gasket from the old water pump was not completely removed... thanks for the advice guys! Problem solved! Link to comment Share on other sites More sharing options...
