Tuners Rejoice! Free Tuning For M4.4!
  • Replies 7.7k
Ok, idiot question of the night. Is there a overboost/load table? If so is it the "Overcharge-Load" table?
I set the pressure ratio map super high and it didn't really do anything. Pretty much stayed stock which is when i first give it WOT it spikes to about 13-14psi and the levels out at around 10psi. I am being real cautious with this and asking before i dig too deep.
Set RPM diagnosis of overboost to 7500.
Set all values of overcharge-load to 12.
Report back with how those differences affected things.
Wouldnt increasing the requested pressure ratio map, increase requested load which would in terms increase boost? Confused at why you arnt seeing an increase in power, unless you didnt increase the values in the parts of the map you were driving in.
I didn't change the Overcharge load table which would limit the load/boost
I just compiled a list of every map referenced by the main RPM axis. I am now working on seeing which ones will need to be modified if the RPM axis is modified and which ones don't matter.
Also, as for scaling for a larger MAF, I think I just figured it out yesterday and it is quite simple. Just scale all three load axis's by the ratio of (old area)/(new area). It will decrease all of the load values, but no map modification would be necessary However, you would still be going over the maximal value of load unless you adjust the axis to go higher, which would require the modification of maps.
Does anyone have a larger MAF they could test out? I could send a modified .bin for testing purposes.
