S70NA Posted March 8, 2013 Report Share Posted March 8, 2013 Anyone ever have this issue? I went to drive the car up some ramps using two footed driving, both pedals slightly depressed, and the vehicle went into a "blank mode" with no response whatsoever. It drives normally otherwise. This is a 99 S70 NA Base No Mods. 2.4L w/AT. Any help would be appreciated. Thanks in advance. Link to comment Share on other sites More sharing options...
JRL Posted March 8, 2013 Report Share Posted March 8, 2013 Failing ETM or Failed or failing brake switch which affects the ETM No CELs? Link to comment Share on other sites More sharing options...
831t5r Posted March 8, 2013 Report Share Posted March 8, 2013 With the brake pedal applied and stepping in gas did rpms move or rev? Brake pedal always over rides the accelorator Link to comment Share on other sites More sharing options...
James A Sousa Posted March 9, 2013 Report Share Posted March 9, 2013 Try using your emergency brake, keep the button in. You can try this in the parking lot, you don't have to wait until you are using the ramps again. Link to comment Share on other sites More sharing options...
jschaefer7406 Posted March 10, 2013 Report Share Posted March 10, 2013 With the brake pedal applied and stepping in gas did rpms move or rev? Brake pedal always over rides the accelorator Not unless it's an N/A thing. I've power jacked my '00 AWD before, RPM's rise as normal... Joe Link to comment Share on other sites More sharing options...
S70NA Posted March 20, 2013 Author Report Share Posted March 20, 2013 Hey Guys, thanks for the responses. The tachometer does not move at all with scenario stated. With e brake on and no brake pedal, the car responds under throttle. There are T5s and 2.4Ts all around me and none of them had ever witnessed this. JRL: No CELs. I will look into the brake switch and if that is good, then the ETM. Just noticed the extended warranty for the ETM just before typing this. Thanks. Link to comment Share on other sites More sharing options...
Stefan Mohammed Posted March 22, 2013 Report Share Posted March 22, 2013 I had this problem with my old 2.9 (B6294S) that was in my S80... it was a failing ETM. Hope it helps Link to comment Share on other sites More sharing options...
S70NA Posted March 24, 2013 Author Report Share Posted March 24, 2013 Great! Thanks again Guys. I will look at this this coming weekend. Will let you know what I find. Link to comment Share on other sites More sharing options...
