marco bolduc Posted April 8, 2013 Author Report Share Posted April 8, 2013 got nothing to do this weekend (waiting for so parts) I decided to take the head off the old engine. Piston #1 with a chunk missing: Piston #5 was sideways in the cylinder: Link to comment Share on other sites More sharing options...
lookforjoe Posted April 8, 2013 Report Share Posted April 8, 2013 Congrats on getting the car back! Don't forget to swap the ancillary bracket over - you can't mount the old PS/AC/ALT to the newer bracket. You will have to notch the timing cover for the old tensioner as well. Unless you use the old style small breather box, the alt long bolt needs to be reversed or you cannot access the alternator without first taking off the (newer style) breather box. Dipstick also has to be swapped over. You already installed the early Cam sensor? Can see in your one pic that the int cam has been counterdrilled for the rotor plate, presuming you did the cam sensor plate at the same time. Get a new upper torque mount with the round insert - that way when it goes bad you can insert a round poly bushing. Link to comment Share on other sites More sharing options...
marco bolduc Posted April 8, 2013 Author Report Share Posted April 8, 2013 Congrats on getting the car back! Don't forget to swap the ancillary bracket over - you can't mount the old PS/AC/ALT to the newer bracket. You will have to notch the timing cover for the old tensioner as well. Unless you use the old style small breather box, the alt long bolt needs to be reversed or you cannot access the alternator without first taking off the (newer style) breather box. Dipstick also has to be swapped over. You already installed the early Cam sensor? Can see in your one pic that the int cam has been counterdrilled for the rotor plate, presuming you did the cam sensor plate at the same time. Get a new upper torque mount with the round insert - that way when it goes bad you can insert a round poly bushing. everything is done! i'm actually waiting for the 19T from Spanky and the pcv kit from IPD. then the engine will go right in! I'm using the old style pcv and aux bracket! I add to trim the timing cover a bit but the final result is really clean! I also installed an ''R'' fuel rail cover (I had to trim the bottom since the manifold runner are not at the same place and I had to trim the right side in order to get the throttle cover on). Link to comment Share on other sites More sharing options...
marco bolduc Posted April 9, 2013 Author Report Share Posted April 9, 2013 yahoo! got A big Box of parts this morning! received everything PCV related with the catch can! i'm waiting for the turbo and the engine will be in the car this weekend! GunMetal Catch Can! Link to comment Share on other sites More sharing options...
Tommy. Posted April 9, 2013 Report Share Posted April 9, 2013 sweet catch can! Looking forward to this! Did you clean that bay yet? Link to comment Share on other sites More sharing options...
Brickbox8398 Posted April 9, 2013 Report Share Posted April 9, 2013 I'll never understand why ppl go through the hassle of making their cars better/more fun, then selling them quickly thereafter.... Good read, best of luck. EXACTLY! You're wayyy better off getting your money and efforts worth by keeping the car and enjoying it. I'm in the same position with mine right now and i couldn't imagine selling it after all the blood sweat and tears i've put into it the past 2 years. Link to comment Share on other sites More sharing options...
marco bolduc Posted April 9, 2013 Author Report Share Posted April 9, 2013 EXACTLY! You're wayyy better off getting your money and efforts worth by keeping the car and enjoying it. I'm in the same position with mine right now and i couldn't imagine selling it after all the blood sweat and tears i've put into it the past 2 years. You Are defenitly right! I had to sell the car because I needed money to start in life! I finally bought my house last year so the timing was just perfect to get the car back! like you said, after all the blood, sweat and tears iv'e put into this car, there was no reason for me to let it go to someone else! Link to comment Share on other sites More sharing options...
Commander Riker Posted April 10, 2013 Report Share Posted April 10, 2013 Good luck on the build. I too was surprised to find the R mani with I picked up the later motor. Always a nice bonus! You're going to love that RN motor. Good luck! Link to comment Share on other sites More sharing options...
marco bolduc Posted April 15, 2013 Author Report Share Posted April 15, 2013 Clutch Kit and Transmission are know bolted to the new engine. I only waiting for the 19T. once the turbo arrives, the engine will go right in! Link to comment Share on other sites More sharing options...
marco bolduc Posted April 16, 2013 Author Report Share Posted April 16, 2013 Got the Turbo this morning! it looks really nice. Link to comment Share on other sites More sharing options...
marco bolduc Posted April 18, 2013 Author Report Share Posted April 18, 2013 Yahoo! new turbo is installed, Engine is in the car, transmission oil change is made, axles are on. I currently waiting for some hoses for the catch can and the intake should on tonight. Firt start-up should be this weekend, if I can find someone with a S70 T5 that I can borrow is ECU! I love new turbo!: engine in! I know someone who is coming off!: Link to comment Share on other sites More sharing options...
marco bolduc Posted April 22, 2013 Author Report Share Posted April 22, 2013 Finally up and running! after passing the weekend struggling with a damn p0340! after testing with a new cam sensor, I redid a part of the engine harness. finally it was the ECU I borrowed from a friend that was short on the cam sensor inner circuit! I removed the Climate controle module and dropped in a 850 turbo ecu and it runs with no problems! I did a couple of miles on the new setup, did'nt boost over 10psi since I don't have my tune yet. Link to comment Share on other sites More sharing options...
Jesus Posted April 23, 2013 Report Share Posted April 23, 2013 Damn, dude. Looks good. Link to comment Share on other sites More sharing options...
Tommy. Posted April 23, 2013 Report Share Posted April 23, 2013 Amazing work. Love how the wheels fit so well with the car Link to comment Share on other sites More sharing options...
Brick Guy Posted April 23, 2013 Report Share Posted April 23, 2013 Can you post some more pics of you oil catch can and what parts, etc you used? Link to comment Share on other sites More sharing options...
