Lots Of Oil On Rear Of Block, Under Axle, Not Turbo Return Line, Rms Seems Ok...heads Together Now And 1,2,3, Think!
Pops Racer
1995, 855, T5, 2000000000000 miles.
Yup, back for help. Leak is pretty extensive. blowing under car burning on exhaust, making lift gate filthy.
Bmac just did turbo return O-ring.
RMS, PCV, done about 100k ago, RMS seeems ok. What else is left? crank seals?
Thanks.
Oh yeah, Obama sucks.
  • Replies 31
I gotta get back on here more often you guys are a hoot, seriously smart asses with a sense of humor.
Yes it's true, more info. I did replace the turbo return line o-ring. Then I went to a power wash joint. Sprayed down the block and under carriage with brake clean then simple green, a great degreaser that offset the chlorine solvents I sprayed all over the engine.
So after that I did see some oil drip from the subframe and smell burning oil on the exhaust.
But about 60 miles after the block still looks clean and the burning smell had subsided.
I'm hopefull that this is the cause. I'm keeping an eye on it and will update in a few days.
Everything is political especially oil and the environment.
I still think it's the cam seals, but it's hard to tell with an engine with 2000000000000 miles. That's a shit-ton of miles, and it really could be anything at that point.
