Stefan Mohammed Posted April 3, 2013 Report Share Posted April 3, 2013 Hey guys, The clockspring for my 2000 S80 2.9 RHD is torn. I can't locate a part number on it and the only identifying lablel is a barcode with the text *1TH0507*A on it. I searched up on VIDA and I found several part numbers for my clockspring. I'm not sure which part number I need. The connector into the SWM is a 4 pin connector located on the top right of the clockspring and the connectors on the steering wheel side are: (1) 2-Wire Airbag Connector (orange cable sleeve, wire colours blue and brown), (1) 2-wire Horn Connector (grey jack, wire colours green and white) and, (1) 3-Wire Steering Wheel Control Connector (Green Connecor with 10 holes, 3 wires, wire colours blue, red, black). The Steering Wheel and Horn connector cables are sleeved together in a black sleeve. The steering wheel controls that came on the car were for cruise control and for audio control. The car came with a HU601 Headunit (no RTI) and standard cruise control (STC only). Steering Wheel Side of Spring (Note wire colours) Green connector is for steering wheel controls and grey is for the horn Steering wheel connector (grey) and horn connector (grey). Pinouts are: (STEERING WHEEL CONTROLS: 1-Blue, 2-Red, 3-Black, 4-EMPTY, 5-EMPTY) (HORN: 1-White, 2-GREEN). Single airbag connector (2 wires in orange sleeve) Alternate view of single airbag connector (2-wires in orange sleeve) Barcode on the side of the clockspring SWM connector on clockspring (the internal spring/pins are removed in this picture but it's a 4 pin connector). If you are looking head on to the clockspring (the side with the warning label on it) then this connector is at the top-right of the steering wheel. Thanks a mil - Stefan. [EDIT] VIN Number: YV1TS94C5Y1069110 Link to comment Share on other sites More sharing options...
Oreo931 Posted April 3, 2013 Report Share Posted April 3, 2013 You need your chassis number to verify the correct p/n. http://www.volvopartswebstore.com/showAssembly.aspx?ukey_product=1191882&ukey_assembly=243578&ukey_make=865&ukey_model=12010&ukey_driveline=496&ukey_trimlevel=0&modelYear=2000 http://www.volvopartswebstore.com/productSearch.aspx?&ukey_make=865&modelYear=2000&ukey_model=12010&ukey_trimLevel=0&ukey_driveline=496&ukey_Category=7858&numResults=100&sortOrder=Relevance&isOnSale=0&isAccessory=0&isPerformance=0&searchTerm=clock%20spring Link to comment Share on other sites More sharing options...
Stefan Mohammed Posted April 4, 2013 Author Report Share Posted April 4, 2013 So CH is chassis number then! Boy do I feel stupid now! Just to clarify, does EXC mean excluding? Thanks oreo!! Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 4, 2013 Report Share Posted April 4, 2013 Yes EXC in the parts fish means excluding. Link to comment Share on other sites More sharing options...
Stefan Mohammed Posted April 5, 2013 Author Report Share Posted April 5, 2013 Thank's guys... seeing as my chassis number is 069110 and my car does not have DSTC, I assume the part number I need is 9157061 from the parts list oreo provided. Thanks again! Link to comment Share on other sites More sharing options...
