jdlc Posted April 3, 2013 Report Share Posted April 3, 2013 No plan to replace 13T on my 2.4T GLT engine. For those who actually done it, any noticeable power gain? Is it worth it for about $120? Thanks Link to comment Share on other sites More sharing options...
caanglin Posted April 3, 2013 Report Share Posted April 3, 2013 I did just the ecu and there was not much, if any difference. Link to comment Share on other sites More sharing options...
jdlc Posted April 3, 2013 Author Report Share Posted April 3, 2013 Thanks.^^^ Anybody who did the combo who believed he was able to get a fraction of the 48 horses spread (for 98) between GLT and T5? Link to comment Share on other sites More sharing options...
cheat2win99 Posted April 3, 2013 Report Share Posted April 3, 2013 if you want a much quicker car, i'd suggest you replace your turbo with a 16t, top end pulls sooo much better. Link to comment Share on other sites More sharing options...
Yellow95 Posted April 3, 2013 Report Share Posted April 3, 2013 I did 16t and ecu. The car was scarey quick. Link to comment Share on other sites More sharing options...
phunktified Posted April 3, 2013 Report Share Posted April 3, 2013 I noticed a difference in my 850 with a t5 ecu on a 13g.. didnt bother with the injectors at the time .. seemed to wake it up a bit .. that setup+16T in my v70 tho --> big difference. night and day .. Link to comment Share on other sites More sharing options...
jdlc Posted April 3, 2013 Author Report Share Posted April 3, 2013 Thanks guys. I have no doubt about the 16T factor . Seems like ecu is a good start and maybe not bother with the white injectors - after all reds flow better than orange found in 850 turbo/T5 from what I gather. There's nothing wrong with my 13T and was just trying to get drop-in bang for buck mod. Done R mani install and DIY refurbed the 16T in my previous 98 T5M and I don't want to do it again as my back is not as young as it used to be : ) Link to comment Share on other sites More sharing options...
caanglin Posted April 3, 2013 Report Share Posted April 3, 2013 I wouldn't bother with the injectors. I ran a 15G and T5 ecu (stock red injectors) on my 98 GLT with a OBX for 2+ years with zero issues. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted April 3, 2013 Report Share Posted April 3, 2013 Just flash a new .bin on your ECU and use the red. No need to spend any money, except for the VAG-COM cable. Link to comment Share on other sites More sharing options...
Yellow95 Posted April 3, 2013 Report Share Posted April 3, 2013 Just flash a new .bin on your ECU and use the red. No need to spend any money, except for the VAG-COM cable. QFT Link to comment Share on other sites More sharing options...
jdlc Posted April 3, 2013 Author Report Share Posted April 3, 2013 I have a 98. Only 99+ can be flashed in car or did that change? Link to comment Share on other sites More sharing options...
Keaton85 Posted April 3, 2013 Report Share Posted April 3, 2013 You have that backwards.... Link to comment Share on other sites More sharing options...
jdlc Posted April 3, 2013 Author Report Share Posted April 3, 2013 Golly gee - Im obviously not paying attention to it, but Ipd sells (used to?) 99+ flasher which I knew not to work with earlier cars. This vag business is cool IF there's a known/stable mod for 98 GLT .bin file floating around for FREE in the forum. Is there one? Link to comment Share on other sites More sharing options...
Keaton85 Posted April 3, 2013 Report Share Posted April 3, 2013 first page in the performance section. But personally, I think it's a waste of time with a 13T or 13G when 15G and 16T turbos are a dime a dozen and well worth the time and money. Link to comment Share on other sites More sharing options...
Horses With Gas Posted December 17, 2013 Report Share Posted December 17, 2013 Just flash a new .bin on your ECU and use the red. No need to spend any money, except for the VAG-COM cable. (Referencing the 4.4 tuning thread) I wonder how far off a T5 map is from a GLT map of the same year. Some people simply swap a T5 ecu and injectors (maybe) into the LPT and report no problems. But others have reported misfires or rough idling with a T5 or R ECU swap into an LPT vehicle. I suspect that the T5 ecu adaptibility is being pushed to (or past) its limit. Starting from a T5 .bin, I suppose that changing the injector constant is just a starting point to get the T5 code to be optimized for a LPT vehicle. Link to comment Share on other sites More sharing options...
