Matty Moo Posted April 6, 2013 Report Share Posted April 6, 2013 Mounting the torque converter to the trans in a 2000xc. Now...I have the torque converter on but I don't know the exact specs for the space between the flexplate mounting bolt flanges on the torque converter and the face of the transmission housing. I know on the earlier FWD automatics it's .55", but not sure about this one. If anybody could help, that would be swell. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 6, 2013 Report Share Posted April 6, 2013 Don't know the spec, but if you post a picture I'll tell you if the torque converter is in far enough. Link to comment Share on other sites More sharing options...
Matty Moo Posted April 7, 2013 Author Report Share Posted April 7, 2013 Don't know the spec, but if you post a picture I'll tell you if the torque converter is in far enough. I appreciate it, I figured it out right after you posted that. The yard we got the trans from just put the torque converter loosely on the output shaft screwing up the splines in the converter ever so slightly. Luckily we had a spare from when we did Dan's manual swap, popped it right on with no issues. Only took about one minute to find that spot where it bottoms out. Link to comment Share on other sites More sharing options...
