boxpin Posted April 30, 2013 Author Report Share Posted April 30, 2013 Congrats! Are you using 850R clutch? If so any slippage at current power levels? Stock internals? R clutch, I could smell rubber but not clutch H-beams Yea, maybe switching up the boost control method to a manual or after market electronic setup would be your best bet. Although it is probably possible to get it to work correctly on the current setup, its hard without them being able to change the tune and see the results immediately I might do that, at least it would eliminate the boost management as a suspect. Link to comment Share on other sites More sharing options...
ARD - Lucky Posted May 1, 2013 Report Share Posted May 1, 2013 Solid numbers, did we really tune that past 7500 RPM...? Link to comment Share on other sites More sharing options...
mercuric Posted May 1, 2013 Report Share Posted May 1, 2013 Awesome! Curious, which wideband are you running? Link to comment Share on other sites More sharing options...
RZT5 Posted May 1, 2013 Report Share Posted May 1, 2013 Solid numbers, did we really tune that past 7500 RPM...? Doesn't sound like 7500 in the vid, and that graph looks like a 20G on a whiteblock going up to 6000, not 7500. I bet they had the dyno setup to read rpm for a 4 cylinder. Link to comment Share on other sites More sharing options...
boxpin Posted May 1, 2013 Author Report Share Posted May 1, 2013 Doesn't sound like 7500 in the vid, and that graph looks like a 20G on a whiteblock going up to 6000, not 7500. I bet they had the dyno setup to read rpm for a 4 cylinder. I told the guy to go to 7000 but he didnt, its like a bit over 6000. Link to comment Share on other sites More sharing options...
mercuric Posted May 1, 2013 Report Share Posted May 1, 2013 Doesn't sound like 7500 in the vid, and that graph looks like a 20G on a whiteblock going up to 6000, not 7500. I bet they had the dyno setup to read rpm for a 4 cylinder. Check the in-car video from the run, you can see the tach.. I think you are exactly right. This also would mean the "hiccup" on the plot around 5500 is actually at 4500. Link to comment Share on other sites More sharing options...
boxpin Posted May 1, 2013 Author Report Share Posted May 1, 2013 Check the in-car video from the run, you can see the tach.. I think you are exactly right. This also would mean the "hiccup" on the plot around 5500 is actually at 4500. I agree, seems like 4500 is where it happens. It pulls then releases then pulls hard. Link to comment Share on other sites More sharing options...
VolvoLifer Posted May 1, 2013 Report Share Posted May 1, 2013 I dyno'd later in the evening and paid for one pull. It also showed it rev'd to 7500 and everyone watching went wait a minute, that is wrong. They had it calibrated wrong and after we pointed that out, fixed it. Then they had to give me another free pull because the first one was wrong. 1st pull 240 hp - 220 tq 2nd pull 240 hp - 283tq So the hp numbers were still accurate but when it got recalibrated, my tq went way up like it should be with my setup. The rpm was also where it should be. Then it was like hey, if they have been doing it this way the whole time, what happened to people before me? So I would believe hp numbers are probably accurate just based on my car having it done both ways, the only thing that changed was tq. Link to comment Share on other sites More sharing options...
lookforjoe Posted May 1, 2013 Report Share Posted May 1, 2013 Solid numbers, did we really tune that past 7500 RPM...? Not much point, unless you have a short runner/lager plenum intake going in :-) Link to comment Share on other sites More sharing options...
Volvo5.0 Posted May 1, 2013 Report Share Posted May 1, 2013 I agree, seems like 4500 is where it happens. It pulls then releases then pulls hard. Look at the boost gauge at around the 39-40 second mark of the in car video. You can definitely see the needle dip momentarily and then recover. I'd bet it's a boost control issue. I had the exact same problem (hp dropped and then recovered) when I was on the dyno. I could also feel the exact thing you're feeling when driving the car. I log my boost (along with other parameters) and I swear if I were to overlay my boost log on top of my dyno graph, it would line up perfectly. Going to an EBC was the fix for me. I haven't been back to the dyno, but the logs clearly show the huge improvement in boost control. Link to comment Share on other sites More sharing options...
lookforjoe Posted May 2, 2013 Report Share Posted May 2, 2013 I have a spare Greddy Profec if you're interested... Link to comment Share on other sites More sharing options...
boxpin Posted May 14, 2013 Author Report Share Posted May 14, 2013 Hah!! I have a leaking BOV!! .....MORE POWER COMING!! Link to comment Share on other sites More sharing options...
cgally Posted May 16, 2013 Report Share Posted May 16, 2013 Congrats on your new combination. Nobody has commented on low torque numbers. Would incorrect dyno calibrations throw those numbers off that much? Link to comment Share on other sites More sharing options...
boxpin Posted May 16, 2013 Author Report Share Posted May 16, 2013 We are learning that they did not have the dyno setup correctly for our cars that day. HP is accurate but most of the other settings are off. It was not identified till later in the evening. Link to comment Share on other sites More sharing options...
