jnderr Posted May 8, 2013 Report Share Posted May 8, 2013 For sale are a set of 5 139.5mm H-Beam connecting rods. These come without rod bolts, you will need a total of 10 3/8" x 1.6" rod bolts for them the ARP part number is: 200-6209 for a set of 8 and then ARP 200-6219 for a single pair. 2.3L builds may require some machining of the lower bore for clearance. Price is $300 shipped conus. Link to comment Share on other sites More sharing options...
jnderr Posted May 13, 2013 Author Report Share Posted May 13, 2013 $280 shipped conus anyone? Link to comment Share on other sites More sharing options...
jnderr Posted May 21, 2013 Author Report Share Posted May 21, 2013 $250 shipped conus. Link to comment Share on other sites More sharing options...
volvoskiah Posted May 21, 2013 Report Share Posted May 21, 2013 Awesome deal! Link to comment Share on other sites More sharing options...
HiPSI Posted May 21, 2013 Report Share Posted May 21, 2013 I'm extremely interested, but don't want to have to go thru the expense of machining. Could you clarify if these will require a 98 T5 2.3 to have the lower bore machined? Thanks. Link to comment Share on other sites More sharing options...
jnderr Posted May 21, 2013 Author Report Share Posted May 21, 2013 I'm extremely interested, but don't want to have to go thru the expense of machining. Could you clarify if these will require a 98 T5 2.3 to have the lower bore machined? Thanks. I have not installed these so I could not say for sure. But they are on the wide side on the bottom end. Its not a big deal to notch the block, you can do it with a die grinder or even a dremel. Link to comment Share on other sites More sharing options...
TRACStar Posted May 21, 2013 Report Share Posted May 21, 2013 I can check pictures later but they look identical to the rods in my block and I had zero clearance issues. I believe the step that is at the bottom where the bolt head seats in earlier versions ran to the bottom of the rod which would hit the block walls. Link to comment Share on other sites More sharing options...
jnderr Posted May 21, 2013 Author Report Share Posted May 21, 2013 I can check pictures later but they look identical to the rods in my block and I had zero clearance issues. I believe the step that is at the bottom where the bolt head seats in earlier versions ran to the bottom of the rod which would hit the block walls. Much appreciated! Link to comment Share on other sites More sharing options...
jnderr Posted May 22, 2013 Author Report Share Posted May 22, 2013 Last call before ebay Link to comment Share on other sites More sharing options...
boxpin Posted May 22, 2013 Report Share Posted May 22, 2013 So many Volvo owners want to build their engines and here are rods at a fantastic price and nobody is biting. Link to comment Share on other sites More sharing options...
DScottM Posted May 22, 2013 Report Share Posted May 22, 2013 If this was one year from now I'd bite Link to comment Share on other sites More sharing options...
jnderr Posted May 22, 2013 Author Report Share Posted May 22, 2013 Perhaps the number of built motors has reached critical mass. No worries. Link to comment Share on other sites More sharing options...
corivus Posted May 23, 2013 Report Share Posted May 23, 2013 hrmmm may pick this up from you next month, apparently the g/f's parents are paying for the wedding so I don't have to save up as hard as I thought I would Link to comment Share on other sites More sharing options...
gilber33 Posted May 24, 2013 Report Share Posted May 24, 2013 If you still have these in 17 months, I'll totally get them from you. Link to comment Share on other sites More sharing options...
boxpin Posted May 24, 2013 Report Share Posted May 24, 2013 He just might. Link to comment Share on other sites More sharing options...
