pedro fandango Posted June 18, 2013 Report Share Posted June 18, 2013 my Kinugawa 11blade turbine turned up this today, & tbh i'm a bit worried by some of the work on it. I understand it needs balancing, but the nut has just been attacked by an angle grinder. Obviously it'll get rebalanced when i get it fitted, but there does look like quite a bit of metal has been taken off so wondering if someone in the know thinks its ok. I'm not expecting it to look pretty for the price, but i would like to know its safe to use many thanks Duane Link to comment Share on other sites More sharing options...
boxpin Posted June 18, 2013 Report Share Posted June 18, 2013 The attack means its been balanced independently. Although, judging by the method used I would have it checked. Link to comment Share on other sites More sharing options...
pedro fandango Posted June 18, 2013 Author Report Share Posted June 18, 2013 The attack means its been balanced independently. Although, judging by the method used I would have it checked. i appreciate that, i was just worried by how much they've taken off (& probably by the fact its just been done by hand). You don't think they could of weakened the nut or anything by taking that much off Link to comment Share on other sites More sharing options...
blkaplan Posted June 18, 2013 Report Share Posted June 18, 2013 thats odd how they shaped the webbing on the turbine wheel. and yes, the grinding on the nut is how they balance them. Those nuts don't have much load on them, i wouldn't worry about it on a structural basis. Link to comment Share on other sites More sharing options...
pedro fandango Posted June 18, 2013 Author Report Share Posted June 18, 2013 thats odd how they shaped the webbing on the turbine wheel. and yes, the grinding on the nut is how they balance them. Those nuts don't have much load on them, i wouldn't worry about it on a structural basis. here's a better pic of the rear showing the design, looking side on the nut the & it looks like their not far off going thru to the shaft at one part of the grinding. I'll have to find a specialist in the area & see what they think Link to comment Share on other sites More sharing options...
lookforjoe Posted June 19, 2013 Report Share Posted June 19, 2013 Looks pretty normal - if there were no grinds anywhere on it I would be more concerned. Any balancing is going to involve removing material wherever it needs to be. You can see where this compressor wheel was similarly ground for balance Link to comment Share on other sites More sharing options...
