Kevin. Posted July 8, 2013 Report Share Posted July 8, 2013 Does anyone know if its possible to get a 850R remote to work in a non R? If so, what would need to be swapped? Thanks Link to comment Share on other sites More sharing options...
Oreo931 Posted July 8, 2013 Report Share Posted July 8, 2013 There's no such thing as an 850R-specific remote. What year is your car? Whether the remote will work depends on what style remote you have and which receiving module (like your ass) is in your car. Edit: What does your remote look like? And what month/year was your car made? You can look for the keyless receiver box, too. In 1995 thru early 1996 cars, the receiver is behind the glove box, on the right hand side. In late 1996 thru 1997 cars, the receiver is under the driver side kick panel IIRC. Link to comment Share on other sites More sharing options...
Kevin. Posted July 8, 2013 Author Report Share Posted July 8, 2013 1996 850 turbo, looks like the standard remote. Here's a pic Link to comment Share on other sites More sharing options...
MattyXXL Posted July 8, 2013 Report Share Posted July 8, 2013 It doesn't go by looks, it goes by the number on the back of the remote.. You can also look at the number on the module behind the glove box Link to comment Share on other sites More sharing options...
gmsgltr Posted July 8, 2013 Report Share Posted July 8, 2013 i thought all the r's had the longer one with the panic button Link to comment Share on other sites More sharing options...
Kevin. Posted July 8, 2013 Author Report Share Posted July 8, 2013 That's what I'm talking about using, the longer style remote with three buttons on it Link to comment Share on other sites More sharing options...
MattyXXL Posted July 8, 2013 Report Share Posted July 8, 2013 If your car didnt come with it.. No you cant use it unless you swap out the Module in the dash. If you swap it all you will have to do is program it.. Link to comment Share on other sites More sharing options...
Kevin. Posted July 8, 2013 Author Report Share Posted July 8, 2013 So if I get a module from a wrecked R and get a new 850R remote all I have to do is program it? Sweeeet Link to comment Share on other sites More sharing options...
MattyXXL Posted July 8, 2013 Report Share Posted July 8, 2013 As long as the numbers match. yes Link to comment Share on other sites More sharing options...
Kevin. Posted July 8, 2013 Author Report Share Posted July 8, 2013 So just get the corresponding remote to the module and I will be good then? Link to comment Share on other sites More sharing options...
MattyXXL Posted July 8, 2013 Report Share Posted July 8, 2013 Yes indeed, you should be able to find a module and then get the remote Link to comment Share on other sites More sharing options...
s_moneh Posted July 8, 2013 Report Share Posted July 8, 2013 i'll just chime in here. remember theres 3 different kinds of "modules" you have the "basic alarm", "Guard Alarm 1", "Guard alarm 2" Guard alarm 2 doesnt have the module in the glovebox it gets replaced by a "2step" relay under the driverside dash. this is essntially the top of the line alarm that came in the 850's serials don't have to match anything as well. i'm currently using a 960 remote on my 850. aslogn as its the same looking type of remote it will work heres my info... http://www.volvoclub.org.uk/tech/service/850/AntiTheftSystem.pdf Link to comment Share on other sites More sharing options...
Kevin. Posted July 8, 2013 Author Report Share Posted July 8, 2013 So, I would have to swap all of that stuff over as well? Including the relays? Link to comment Share on other sites More sharing options...
MattyXXL Posted July 8, 2013 Report Share Posted July 8, 2013 serials don't have to match anything as well. i'm currently using a 960 remote on my 850. aslogn as its the same looking type of remote it will work Not fully acurate, for example only a 9148646 remote will work with my yellow and only a 3545653 will work on my 96 T5 Only certain Remotes will work with certain modules that's where the numbers come in Link to comment Share on other sites More sharing options...
Kevin. Posted July 8, 2013 Author Report Share Posted July 8, 2013 So will I need to confirm which alarm system came in my car before getting a R module or can I just get the R module and remote and make kt work Link to comment Share on other sites More sharing options...
