rainbowboy Posted July 18, 2013 Report Share Posted July 18, 2013 I replaced my 2000 volvo s40 auto. front wheel drive passenger side output axle seal two times with two brand new seals within 3 days. It just continues to leak around the seal. It feels and looks like the axle is seating properly but I just dont know what is going on. I need some body to tell me what im doing wrong or whats going on? Thx in advance. Link to comment Share on other sites More sharing options...
Timbo Slice Posted July 18, 2013 Report Share Posted July 18, 2013 Are you talking about the CV boot? Also, did you clean the area so it is grease free after the install? Link to comment Share on other sites More sharing options...
rainbowboy Posted July 18, 2013 Author Report Share Posted July 18, 2013 Thx for the reply but I may be misleading on the part im talking about. Im talking about the passenger side "output shaft seal" as for cleaning it yes it was very clean when reinstalling the axle. Link to comment Share on other sites More sharing options...
Timbo Slice Posted July 19, 2013 Report Share Posted July 19, 2013 I would take extra time to make sure you're seating it properly. It's either in or now. If you're sure it's seated properly, you may just have the misfortune of two bad seals, but I'd consult VADIS to make sure you're doing it properly. Link to comment Share on other sites More sharing options...
DVolvoguy850T5 Posted July 28, 2013 Report Share Posted July 28, 2013 Have you checked the axel shaft to see if there is a grove worn into it? I've seen this happen with harmonic balancers. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 29, 2013 Report Share Posted July 29, 2013 Are you greasing the inner lip of the seal before you install? Also, it's very easy to knick the aluminum in the transmission case which will also cause a leak. Link to comment Share on other sites More sharing options...
