boxpin Posted August 3, 2013 Report Share Posted August 3, 2013 I have two sets of green injectors The only difference is the OHMs readings. One set reads 12 ohm the other 14ohms. The 14ohm injectors work perfect. The 12ohm injectors work perfect but have a terrible time starting the car. When you crank it does not even attempt to fire. After about 30 seconds it begins to pick up one cylinder at a time till it runs. I have tried to turn on the key and let the pump run till it stops then crank, no diff. I have tried to just jump in and turn the key, no diff. I have let the car sit and try, no diff. Hot, cold, no diff. Just struggles to start. Any ideas? Link to comment Share on other sites More sharing options...
DAYWALKER Posted August 4, 2013 Report Share Posted August 4, 2013 maybe that one is a knock off and the calibration is off. Link to comment Share on other sites More sharing options...
lookforjoe Posted August 5, 2013 Report Share Posted August 5, 2013 Weird - the acceptable range is 12.8-14.5 for the Bosch injectors used with M4.x. Link to comment Share on other sites More sharing options...
fwdGTP Posted August 5, 2013 Report Share Posted August 5, 2013 I can't think of a reason really, that's weird. Link to comment Share on other sites More sharing options...
