mattsk8 Posted September 3, 2013 Report Share Posted September 3, 2013 Got another question. I have a 99 V70 R, and (not all the time, but often) when I start it cold first thing in the morning it seems to stumble fairly badly when I accelerate. Also, the other day I was driving it mainly highway for about a 30 mile trip. After it warmed up, the car ran great for a bit, but then started stumbling terribly and almost wouldn't even go 60mph, it also stalled at a stop sign. It did this for about 10 miles, then just cleared up and took off like nothing ever happened. This was about a week ago and the car's been running great ever since, even the cold starts have been good. The car runs great otherwise. About a week prior to this, I got a code P0137 which is for the rear O2 sensor (no engine light prior to the O2 sensor code showing up). I got the codes read again today hoping for some light to get shed on why it was stumbling, but still just the code P0137. I also noticed my mileage went from an average of about 23 down to 20 mpg on this last tank of gas (the tank that had the stumbling episode). That's w/ me doing the math on my mileage, not just using the the thing in the instrument cluster that shows mileage. Any suggestions? Could this be indicative of a failing fuel pump? If it is an indication of a fuel pump going, what pump do you guys recommend for it?? The car has about 160k on it, so I know a new fuel pump is probably a good idea anyhow, just want to be sure I'm not overlooking something else. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted September 3, 2013 Report Share Posted September 3, 2013 Checking fuel pressure at the rail is the only way to verify the fuel pump is doing it's job. These engines can run until (albeit poorly) down to about 1 bar before they stall. Because of the difficulty installing a fuel pump in the AWD models you want to be certain it's the culprit. Normal operating fuel pressure should be about 4 bar. That said, I would first check the age of the fuel pump relay. If the date stamp is original it would be a great idea to replace it as more of a general maintenance item. Also, cracked ignition coils will cause a stumble on cold starts. The reason it doesn't store any misfire codes is because the ECM is still operating in open loop and knock is not detected. This is a pretty common problem with these cars. The code for the rear o2 sensor would be unrelated to your issue. Link to comment Share on other sites More sharing options...
mattsk8 Posted September 4, 2013 Author Report Share Posted September 4, 2013 Checking fuel pressure at the rail is the only way to verify the fuel pump is doing it's job. These engines can run until (albeit poorly) down to about 1 bar before they stall. Because of the difficulty installing a fuel pump in the AWD models you want to be certain it's the culprit. Normal operating fuel pressure should be about 4 bar. That said, I would first check the age of the fuel pump relay. If the date stamp is original it would be a great idea to replace it as more of a general maintenance item. Also, cracked ignition coils will cause a stumble on cold starts. The reason it doesn't store any misfire codes is because the ECM is still operating in open loop and knock is not detected. This is a pretty common problem with these cars. The code for the rear o2 sensor would be unrelated to your issue. Thanks for all the info!! Just out of curiosity, when I check the fuel pressure, what's one bar? How many psi should I be seeing for me to determine it's good, and what psi would be the cutoff to determine I should replace it? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted September 4, 2013 Report Share Posted September 4, 2013 1 bar = 14.7psi. Fuel pressure should always be hovering around 4 bar. If you're getting dramatically lower or higher the fuel pump should be called into question. Link to comment Share on other sites More sharing options...
