clarkerussell Posted September 6, 2013 Report Share Posted September 6, 2013 I just added the factory amp to the SC-816 in my 1998 S70 and my radio reception dropped dramatically. Is there something I can do to fix this? Is it possible that the amp is defective? On a similar note, is there a way to add the diversity antenna to my car? I seem to have the second input on the radio. Thanks. Clarke Link to comment Share on other sites More sharing options...
Yellow95 Posted September 6, 2013 Report Share Posted September 6, 2013 Amp has nothing to do with radio reception. Did you check the antenna plug? Link to comment Share on other sites More sharing options...
burnout8488 Posted September 7, 2013 Report Share Posted September 7, 2013 I just added the factory amp to the SC-816 in my 1998 S70 and my radio reception dropped dramatically. Is there something I can do to fix this? Is it possible that the amp is defective? On a similar note, is there a way to add the diversity antenna to my car? I seem to have the second input on the radio. Thanks. Clarke I think you'd need to add the antenna box (antenna amplifier?) in the rear and run the cable up front. It's behind the driver's side C-pillar interior trim and connects to the rear glass. Take your car apart, get a mental note of what's not there, then go to a junkyard and get everything. Link to comment Share on other sites More sharing options...
(n)A-GAME Posted September 8, 2013 Report Share Posted September 8, 2013 I think you'd need to add the antenna box (antenna amplifier?) in the rear and run the cable up front. It's behind the driver's side C-pillar interior trim and connects to the rear glass. Take your car apart, get a mental note of what's not there, then go to a junkyard and get everything. I looked into adding a diversity antenna for my S70 - it's not worth it, parts are expensive, and are nearly impossible to find used. Took me 6 months to track down the bumper antenna from a full service place on Ebay. If the particular S70 isn't pre-wired for it (mine wasn't, and as far as I know most aren't) it's a guessing game. You need to add in a bumper mounted antenna which consists of a metal plate with a bunch of wires, then you have to run that back to the head unit which is a huge PITA. My research also was not conclusive on whether the "antenna amplifier" is actually necessary. One more vote for "check the antenna lead" - it's very easy not to push it in all the way. Also, you may want to make sure there's no corrosion or anything on the lead. I suppose you could also check to make sure that the amp lead is pushed in all the way and properly shielded - I can imagine how unshielded power running to the HU could interfere with the reception. Link to comment Share on other sites More sharing options...
