Boost Addicted Posted September 7, 2013 Report Share Posted September 7, 2013 Clunking noise from driver side wheel: When starting from a stop, the last second or so of braking. When slowly going over speed bumps. When turning and accelerating. Thought I even heard it once when I started the car. Everything I can check is tight. Was making the noise before I: Rebuilt strut assembly (including upper spring mount) Installed IPD Sway Bars and Endlinks Installed Polly Sub-frame Inserts Had the Car Aligned It is still making the sound!!!! Axel nut is still staked where it was when I tightened it. Rocked the car back and forth (side to side) no noise Jacked up driver's side wheel, put car in drive so that wheel was turning, turned the steering wheel, no noise. Sway Bar endlinks are torqued to spec. What other tests can I do??? Did the metal adhesive give up between the hub and axle??? But this is not a ping but a clunk. Bad Motor mount??? What other tests can I do? Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted September 7, 2013 Report Share Posted September 7, 2013 axle would be my guess, what car? Link to comment Share on other sites More sharing options...
SonaR Posted September 8, 2013 Report Share Posted September 8, 2013 spring seats? Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted September 8, 2013 Report Share Posted September 8, 2013 May sound hard to believe, have the same problem time a go, check better the hub bearing first with the car on the ground. Link to comment Share on other sites More sharing options...
atefitty Posted September 8, 2013 Report Share Posted September 8, 2013 Did you ruin the new strut hat when you installed it? You must keep it from turning when you tighten it up. Must use two wrenches on it. Link to comment Share on other sites More sharing options...
Boost Addicted Posted September 8, 2013 Author Report Share Posted September 8, 2013 Spring seats are new, It made the noise before the struts were out, Car is a 850 T5R, How do I check the hub bearing with the car on the ground? Link to comment Share on other sites More sharing options...
Maxluff Posted September 8, 2013 Report Share Posted September 8, 2013 Sounds like what I just had happened last week: hub bearing assembly... Link to comment Share on other sites More sharing options...
Volvometer Posted September 12, 2013 Report Share Posted September 12, 2013 Sound like a worn CV joint, man Link to comment Share on other sites More sharing options...
Boost Addicted Posted September 13, 2013 Author Report Share Posted September 13, 2013 Ok I think the first clunk was the broken upper spring seat. When I put the car back together and there was still a clunk, thought it was the same. When I went through and re-torqued everything, discovered the lug nuts had loosened up. Torqued them, drove some torqued again, clunk gone! Link to comment Share on other sites More sharing options...
SonaR Posted September 13, 2013 Report Share Posted September 13, 2013 Good save. That could've become really shitty, real quick. Link to comment Share on other sites More sharing options...
Boost Addicted Posted October 2, 2013 Author Report Share Posted October 2, 2013 But the clunk came back the very next day! Replaced Hub assembly, problem solved! Link to comment Share on other sites More sharing options...
SonaR Posted October 3, 2013 Report Share Posted October 3, 2013 good to know!~ Link to comment Share on other sites More sharing options...
p4eAaLcLe Posted October 4, 2013 Report Share Posted October 4, 2013 Very good to know. I've been chasing this gremlin as well! Link to comment Share on other sites More sharing options...
