Volta55 Posted September 10, 2013 Report Share Posted September 10, 2013 first time it shut off ( 5 oclock position ) was after i boosted hard ( maybe 80% throttle, not WOT ) then came back 10 minutes later for 2 days it worked normal, leveled at the 3 oclock position last night it did not come on, but worked this morning no CELs seems like a sensor of some sort?.. i dont think i need to replace the thermostat Link to comment Share on other sites More sharing options...
Simply Volvo Posted September 10, 2013 Report Share Posted September 10, 2013 Coolant Temperature Sensor is probably on its way out. It is connected to the thermostat, little brass fitting. Its a $30 part. Link to comment Share on other sites More sharing options...
Volta55 Posted September 10, 2013 Author Report Share Posted September 10, 2013 +1 and bought thankyou! Link to comment Share on other sites More sharing options...
msestina Posted September 11, 2013 Report Share Posted September 11, 2013 Coolant Temperature Sensor is probably on its way out. It is connected to the thermostat, little brass fitting. Its a $30 part. I have the same issue. Replaced with a brand new Coolant Temperature Sensor did not fix. I think it's intermittent due to brittle insulation on the wiring. Can anyone help tracing where that temp sensor female connector terminates? Want to run new wires but that connector wire gets buried in the engine harness somewhere. Link to comment Share on other sites More sharing options...
