thunderbirdsc Posted September 12, 2013 Report Share Posted September 12, 2013 Can someone ID this wire and what is should go to? Do all the automatic v70's use a alternator with a clutch? You can see in the pictures the color of the wire on one side is a lavender / light purple color while the other side of the connecter almost looks white, but dirty. The car was having a charging issue. The lights would dim and brighten quickly while idling and it will not charge the battery. While I was pulling the alternator I saw this wire with one end broken/clipped and was wondering if this had anything to do with the problem? IMAG0121 by EngineeredCoating, on Flickr IMAG0122 by EngineeredCoating, on Flickr IMAG0123 by EngineeredCoating, on Flickr IMAG0124 by EngineeredCoating, on Flickr Link to comment Share on other sites More sharing options...
survolvo Posted September 13, 2013 Report Share Posted September 13, 2013 Not sure about the wire, but I don't think thats an alternator. Its a AC compressor. Link to comment Share on other sites More sharing options...
thunderbirdsc Posted September 13, 2013 Author Report Share Posted September 13, 2013 The alternator mounts right above the a/c compressor. It is removed in the images Link to comment Share on other sites More sharing options...
Volvometer Posted September 15, 2013 Report Share Posted September 15, 2013 it might be dfco(deceration fuel cutoff valve)...on the diagram, it shows violet control wire to that valve... also there is pwm control wire of that color to the rad fan relay...just check voltage on it with key on, off and see if it has anything Link to comment Share on other sites More sharing options...
Kevin. Posted September 15, 2013 Report Share Posted September 15, 2013 3rd picture.... thats a wire that comes from the battery to the starter, it needs to be connected Link to comment Share on other sites More sharing options...
