FrankenMoose
  • Replies 36
Disregard what I said, reading threads and posting right when I wake up in the morning is a bad idea. Since you are using your 19T turbo and no the stock LPT or T5 turbo it won't make a real difference which long block you use. The LPT's smaller turbo spools quicker than the bigger T5's turbo and that's where the low end or higher end power comes from.
Sigh. My tranny just took a dump today too. Probably going into storage for awhile while I figure things out. I need another daily in the meantime. Best of luck with your swap. I'll miss cruising in the Volvo.
WTH is going on in the PNW!?! your like the 5th person to have drive train issues this month.
Good deal! You may need to find a newer style connector for the exhaust cam solenoid and splice it in, as Volvo changed the connector design in 2001-2002. If your original engines solenoid was replaced at some point, the new connector may be already spliced in to your harness. Either that or use your old solenoid but make absolutely sure that it is not contaminated with metal bits from your engine grenading.
I do. I ordered a new VVT that has the new connector; and verified yesterday that I have the old connector (the B5244T3 did not come with the harness).
Continued break down yesterday. Everything I could get to on the top is removed or disconnected. Just need to get under the car now, and pick up a cherry picker from my friend. Probably pull it in two weeks as next weekend is the wife's b-day,
