BtownVolvo Posted October 10, 2013 Author Report Share Posted October 10, 2013 but no magnet Ya know...I've had a magnet on my plug since I've owned it and I really don't feel like it was entirely necessary. Like, I would understand if it picked up meaningful deposits. But if it's picking up shit worth worrying about, then...well...you've got other shit to worry about. More of a feel-good mod, that magnet. IMO at least. Link to comment Share on other sites More sharing options...
wmartinlsmith Posted October 10, 2013 Report Share Posted October 10, 2013 thank you Reid! Link to comment Share on other sites More sharing options...
Scootdiggity Posted October 11, 2013 Report Share Posted October 11, 2013 reid very interesting but please write back with a review on if you need adapter and how well the plastic hose connector stays in, because when you look at ad for plastic hose connector it sounds like it is one time use only. I dont think plastic is as sturdy as opposed to solid brass version, also should you still use a crush washer with this piece. Link to comment Share on other sites More sharing options...
Piston Slapper Posted October 11, 2013 Report Share Posted October 11, 2013 reid very interesting but please write back with a review on if you need adapter and how well the plastic hose connector stays in, because when you look at ad for plastic hose connector it sounds like it is one time use only. I dont think plastic is as sturdy as opposed to solid brass version, also should you still use a crush washer with this piece. You're no supposed to leave the plastic hose connector in it. Link to comment Share on other sites More sharing options...
Scootdiggity Posted October 11, 2013 Report Share Posted October 11, 2013 You're no supposed to leave the plastic hose connector in it.What I meant by it staying in was during oil draining as plastic connectors like that tend to pop out leaving oil everywhere, and if they are one time use only as in the individual description it says to break it off when done with oil change.Just got confirmation from somebody who has quick drain valve on other volvo site that he has been running since 2012 you do need adapter to run drain plug, he also uses a small zip tie around valve as added measure Link to comment Share on other sites More sharing options...
Piston Slapper Posted October 11, 2013 Report Share Posted October 11, 2013 Ah, yeah... I think I've been spoiled by being able to stand under my car during oil changes. I'm totally getting the valve, but don't see the point of a hose, since I'm positioning a rolling catch barrel under it. And yes, we need a spacer to run it, as has been said already like 3 times. I'd just get the snap ring safety from them instead of having to replace a zip tie every time. Link to comment Share on other sites More sharing options...
TyConn Posted October 11, 2013 Report Share Posted October 11, 2013 How about P2 cars, no spacer needed? Or will my s60R still need it? Link to comment Share on other sites More sharing options...
andyb5 Posted October 12, 2013 Report Share Posted October 12, 2013 S60R should still need the spacer, as the pan is the same as on my 99 R Link to comment Share on other sites More sharing options...
sjmcarz Posted October 12, 2013 Report Share Posted October 12, 2013 Neat product, but I'll keep using the old fashioned drain plug. The quarter inch or so of oil that could possibly be left in the pan because of this product would bother me, or do you think that all of the oil will still drain out? Link to comment Share on other sites More sharing options...
Piston Slapper Posted October 12, 2013 Report Share Posted October 12, 2013 It's probably more like 1/8", or less, and that's only if you're doing it when the pan bottom is perfectly level. Probably going to be almost as much left anyway during a normal oil change just from surface tension holding some in. Link to comment Share on other sites More sharing options...
rmorse Posted October 12, 2013 Report Share Posted October 12, 2013 Neat product, but I'll keep using the old fashioned drain plug. The quarter inch or so of oil that could possibly be left in the pan because of this product would bother me, or do you think that all of the oil will still drain out? Don't you jack the front of your car up when you do oil changes? Link to comment Share on other sites More sharing options...
sjmcarz Posted October 12, 2013 Report Share Posted October 12, 2013 Don't you jack the front of your car up when you do oil changes? Yes I do,just enough to get under there so maybe most if not all of the oil will drain now that I think about it. Either way, I have no problem with the drain plug and just feel more secure keeping it as it is as far as not worrying about something happening to the drain valve and causing a leak. I know I'm being overly cautious, but rather be that than lose all of my oil if the safety clip fails. Link to comment Share on other sites More sharing options...
crc1021 Posted October 14, 2013 Report Share Posted October 14, 2013 I think this is a simple no brainer. You would think something like this would have been everywhere by now. IPD make a magnet that attaches to your oil filter. http://www.ipdusa.com/products/4887/106477-oil-filter-magnet-for-spin-on-filters Best of both worlds!!! Link to comment Share on other sites More sharing options...
854TGA+ Posted October 15, 2013 Report Share Posted October 15, 2013 Neat little product, thanks for the heads up Reid. Cheers T Link to comment Share on other sites More sharing options...
Oreo931 Posted October 15, 2013 Report Share Posted October 15, 2013 Cool. I'm gonna pick up one of these for my 850R DD. Cleaned up the thread, too. Link to comment Share on other sites More sharing options...
