atefitty Posted November 3, 2013 Report Share Posted November 3, 2013 Picked up this 1997 850 n/a yesterday for $675. Kinda rough, it has a blown head gasket and some body damage fromsomeone "backing into it" as the previous owner said. Damage confined to mostly the hood and a couple small dents in each fender. Drivers seat is torn. Starter sounds tired. I see a cam cover locking tool set on ebay from $100-300 for what looks to be the same set. What all do I need to get other than a head gasket set? Are the head bolts re-useable or do I need to replace them? I've done a lot of work on Volvo's but never a head gasket and I want to see if I can have success. It seems though if I just get another whole motor it may even be a better option and cost nearly the same. Any thoughts?http:// Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted November 3, 2013 Report Share Posted November 3, 2013 The best writeup out there: http://www.tracystruesoaps.com/tutorials/850hg/p1.html Replaced the head bolts, they are not re-usable. Link to comment Share on other sites More sharing options...
Simply Volvo Posted November 3, 2013 Report Share Posted November 3, 2013 Also you dont need the cam locking tool or the cam cover pull down tool, they are unnecessary. Everything can be lined up by eye. Link to comment Share on other sites More sharing options...
atefitty Posted November 3, 2013 Author Report Share Posted November 3, 2013 Thats a very thorough write up, thanks..I'm thinking I can get another motor for around 400-600 if I'm lucky. Looking at the cost of sending the head out and having it checked and the cost of a head gasket set and bolts it still seems more reasonable to get another motor. This car is blowing a lot of smoke when running. It would be cool to open it up and see exactly what going on in there. Link to comment Share on other sites More sharing options...
atefitty Posted November 3, 2013 Author Report Share Posted November 3, 2013 yeh, I see a lot of post about people using cam locking tools for timing belt removal. Shoot, if it moves you just move it back. What up with this obsession with cam locking tools. I can see the need for one when removing the cam cover as it holds everything steady and keeps the cams safe when removing the cover. the guy in the write up made his own. "From a bunch of scraps!." "But I'm not Tony Stark.",haha. Link to comment Share on other sites More sharing options...
goldponcho Posted November 3, 2013 Report Share Posted November 3, 2013 John, I've got the cam lock set, and work in Tacoma these days. Lemme know if you want to borrow it for your project. Link to comment Share on other sites More sharing options...
atefitty Posted November 3, 2013 Author Report Share Posted November 3, 2013 Cool. did you get it off ebay?. I see them for as low as $108.00 Link to comment Share on other sites More sharing options...
goldponcho Posted November 3, 2013 Report Share Posted November 3, 2013 Craigslist, I think. Link to comment Share on other sites More sharing options...
gilber33 Posted November 3, 2013 Report Share Posted November 3, 2013 The best writeup out there: http://www.tracystruesoaps.com/tutorials/850hg/p1.html Replaced the head bolts, they are not re-usable. Why the fuck does she remove the starter, serpentine belt, and fan shroud? Replacing the head is actually really easy. I just did a hg gasket about a month ago with no write up. You really don't need one, it's very straight forward. No need to remove the starter, serpentine belt, or fan though. Also you dont need the cam locking tool or the cam cover pull down tool, they are unnecessary. Everything can be lined up by eye. Agreed, they are pointless. Haven't used one ever. Link to comment Share on other sites More sharing options...
Simply Volvo Posted November 3, 2013 Report Share Posted November 3, 2013 Why the fuck does she remove the starter, serpentine belt, and fan shroud? Replacing the head is actually really easy. I just did a hg gasket about a month ago with no write up. You really don't need one, it's very straight forward. No need to remove the starter, serpentine belt, or fan though. Agreed, they are pointless. Haven't used one ever. Cause she removed the harmonic balancer for some reason. I guess to check the oil pump. Link to comment Share on other sites More sharing options...
atefitty Posted November 3, 2013 Author Report Share Posted November 3, 2013 On some models you need to remove it to see the mark, but not the 850's. She removed the starter to put in her little wedge on the crank. Link to comment Share on other sites More sharing options...
phunktified Posted November 4, 2013 Report Share Posted November 4, 2013 Tr Why the fuck does she remove the starter, serpentine belt, and fan shroud? Tracy isn't just a girl's name, FYI.. the guy who wrote that is a guy ... Link to comment Share on other sites More sharing options...
gilber33 Posted November 4, 2013 Report Share Posted November 4, 2013 Tr Tracy isn't just a girl's name, FYI.. the guy who wrote that is a guy ... TIL: I don't care. Link to comment Share on other sites More sharing options...
phunktified Posted November 4, 2013 Report Share Posted November 4, 2013 TIL: I don't care. Link to comment Share on other sites More sharing options...
atefitty Posted November 4, 2013 Author Report Share Posted November 4, 2013 http://http://http:// Did a compression test and came up with these numbers. Cylinders 2 and 3 looked wet inside. From what I understand no cylinder should be less than 75% of the highest cylinder. cylinder 1. 185psi 2. 165psi 3. 160psi 4. 190psi 5. 190psi Link to comment Share on other sites More sharing options...
