boxpin Posted November 8, 2013 Report Share Posted November 8, 2013 I just picked these up for my build and wanted to post a picture of them. There has been a lot of talk on what to use for the rods. Either OEM or Toga. I ran the Togas but as some of you know I cracked my rings with a spout of detonation. There were some marks on the toga bearings that made me question their strength and ability to recover from that force. I did some research and came across a technology invented by Glyco, Its called Sputter. The bearings are pricey and come in individual boxes. Someone mentioned that Volvo OEM were sputter but I cannot find anything to support that claim. I know these are and am going to give them a go. https://www.highpowermedia.com/RET-Monitor/3445/what-are-sputtered-bearings Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted November 8, 2013 Report Share Posted November 8, 2013 Did you go with sputter just for the rod side, or did you get a set for the caps too? Link to comment Share on other sites More sharing options...
boxpin Posted November 8, 2013 Author Report Share Posted November 8, 2013 Only the rod side of the bearing is sputter, where the load is. Link to comment Share on other sites More sharing options...
ErikS Posted November 8, 2013 Report Share Posted November 8, 2013 Jan used Glyco sputter on his 850, that engine took some serious abuse. Link to comment Share on other sites More sharing options...
Simply Volvo Posted November 8, 2013 Report Share Posted November 8, 2013 What are you going to do about piston rings? Titanium? Link to comment Share on other sites More sharing options...
boxpin Posted November 8, 2013 Author Report Share Posted November 8, 2013 The pistons are fine, the rings are not. But, I am going Wiseco and boring. Link to comment Share on other sites More sharing options...
lookforjoe Posted November 8, 2013 Report Share Posted November 8, 2013 Can you share the vendor/product #'s? Would be worth keeping fro future reference. I've had good luck with Toga so far, but you never know DTR. Link to comment Share on other sites More sharing options...
Johann Posted November 8, 2013 Report Share Posted November 8, 2013 Those are the standard Glyco for turbo 5 cylinder. Used to be a set of 5 bearings, now they sell boxed per bearing. 71-3926 STD There was some talk about some people using the sputter on the rod side and non on the cap side. I bought a full set and have not decided yet. I am open to opinions. The box comes with one sputter cap per bearing set which goes rod side. Link to comment Share on other sites More sharing options...
boxpin Posted November 8, 2013 Author Report Share Posted November 8, 2013 Those are the standard Glyco for turbo 5 cylinder. Used to be a set of 5 bearings, now they sell boxed per bearing. 71-3926 STD The box comes with one sputter cap per bearing set which goes rod side. You are correct Sir. I pulled the second bearing out and it is indeed not a sputter. Glyco sells two different bearings for the motor. Dont get them mixed up. Standard Bearings: 71-3754/5 or 272197 Sputter Bearings: 71-3926 Link to comment Share on other sites More sharing options...
marlint5 Posted February 19, 2014 Report Share Posted February 19, 2014 I just picked these up for my build and wanted to post a picture of them. There has been a lot of talk on what to use for the rods. Either OEM or Toga. I ran the Togas but as some of you know I cracked my rings with a spout of detonation. There were some marks on the toga bearings that made me question their strength and ability to recover from that force. I did some research and came across a technology invented by Glyco, Its called Sputter. The bearings are pricey and come in individual boxes. Someone mentioned that Volvo OEM were sputter but I cannot find anything to support that claim. I know these are and am going to give them a go. https://www.highpowermedia.com/RET-Monitor/3445/what-are-sputtered-bearings Can you share the link at where you got this, and by chance u have the part no for the rod big end sputter's set? i've ordered Toga, arrived, " thank you hussein" .. .. but it seems, i require oversize set, for my rod big end bearings. and i cant get Toga 10 over, front the supplier. The main bearings is fine with Toga, ill retain and use that, but i need the rod big ends bearing. thank you Link to comment Share on other sites More sharing options...
boxpin Posted February 19, 2014 Author Report Share Posted February 19, 2014 These are Rod bearings only. Mains you'll have to go Toga, Federal Mogul, Glyco http://www.rockauto.com/catalog/x,carcode,1431521,parttype,5212 Last I had talked to the Toga mfg they said they no longer had Mains and did not know when they would have more...if ever. That was their comment. Link to comment Share on other sites More sharing options...
marlint5 Posted February 20, 2014 Report Share Posted February 20, 2014 Thank you boxpin, yup, i juz need Rod Bearing ( sputter ), my main bearings - Toga. hope they are fine. and yes you are right, contacted Toga supplier....... they dont have it at the moment. thank you again for the Link. have a nice day you all Link to comment Share on other sites More sharing options...
