woah4 Posted December 17, 2013 Report Share Posted December 17, 2013 Heres a picture of the turbo slave as you will recieve it if you get it from rock auto I found on my phone. You can see the circlip inside the cylinder, and if you look at any standard slave you will see that it is not present Link to comment Share on other sites More sharing options...
rcstdad Posted December 18, 2013 Report Share Posted December 18, 2013 Ordered a MC thinking that's what the problem was, but got to spend some time on the car today, and it is the slave. Once I popped the boot off, my precious blue fluid came pouring out! That little boot made a better seal than some gaskets I have used! So, time to order the slave. I guess I have a mc to shelf if it ever decides to bail on me. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted December 18, 2013 Author Report Share Posted December 18, 2013 My slave cylinder is shot, I have to pull the tranny(internal). Spring time project. Link to comment Share on other sites More sharing options...
DAYWALKER Posted December 19, 2013 Report Share Posted December 19, 2013 My slave cylinder is shot, I have to pull the tranny(internal). Spring time project.don't you wish you have a external one Link to comment Share on other sites More sharing options...
rcstdad Posted December 22, 2013 Report Share Posted December 22, 2013 So, I ordered a replacement slave from rock auto. In the mean time, I took mine out to see what was going on. I bought the current slave new back in July. After taking it out, I did confirm what Billy said. There was no circlip holding in the piston. However, if you notice in the photo below, there is a groove under just under the end of the slave that gets covered by the rubber boot. The first bevel of this rubber boot is enough resistance to hold the piston in place during installation. What I did was install a metal tabbed zip-tie to hold this boot onto the slave. If this pops again, I will switch to using a metal pinch clamp (I just didn't have one to use today). Looks like the main thing that keeps the piston from dislodging is the pressure from the bearing fork itself, but the rubber boot must provide some help as well. As Billy also stated, maybe a slightly longer actuator rod would help even with the slave that does not have the circlip. The spring inside the slave will obviously be compressed before the pressure plate receives any pressure. First pic, slave with no boot. You can see the piston just coming out of the end (my index finger hold it in). This pic shows the boot installed with the zip-tie adding additional clamping power. Note: The zip tie must be installed after you fit the slave onto the transmission, as it will not fit through the mounting hole. if this doesn't hold, I'll report back! Link to comment Share on other sites More sharing options...
DAYWALKER Posted December 22, 2013 Report Share Posted December 22, 2013 So, I ordered a replacement slave from rock auto. In the mean time, I took mine out to see what was going on. I bought the current slave new back in July. After taking it out, I did confirm what Billy said. There was no circlip holding in the piston. However, if you notice in the photo below, there is a groove under just under the end of the slave that gets covered by the rubber boot. The first bevel of this rubber boot is enough resistance to hold the piston in place during installation. What I did was install a metal tabbed zip-tie to hold this boot onto the slave. If this pops again, I will switch to using a metal pinch clamp (I just didn't have one to use today). Looks like the main thing that keeps the piston from dislodging is the pressure from the bearing fork itself, but the rubber boot must provide some help as well. As Billy also stated, maybe a slightly longer actuator rod would help even with the slave that does not have the circlip. The spring inside the slave will obviously be compressed before the pressure plate receives any pressure. First pic, slave with no boot. You can see the piston just coming out of the end (my index finger hold it in). This pic shows the boot installed with the zip-tie adding additional clamping power. Note: The zip tie must be installed after you fit the slave onto the transmission, as it will not fit through the mounting hole. if this doesn't hold, I'll report back! when i got my manual swap. i install the used part including the slave cylinder. the slave cylinder piston was more than half way out. all i did was push back the piston with the rod and install it. didn't have a problem. i think if you guys are having problem where the piston come out to far and cause it to leak than probably something is not right. once install it don't suppose to travel that far out. maybe you need longer rod. something is not right with the clutch setup. maybe missing the white piece that the shift fork sit on causing it to travel out farther. Link to comment Share on other sites More sharing options...
woah4 Posted December 22, 2013 Report Share Posted December 22, 2013 Hope it works for ya! It should, I just got tired of the piston coming out and my slaves had no groove to put a circlip in so I got the one with the clip, I've luckily been problem free so far (knock on wood) and we'll see what happens. A longer rod probably would solve it too. Cheers, Billy Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted December 23, 2013 Author Report Share Posted December 23, 2013 Same story after 3 days of normal function, during the night just burst (pop) out all the oil inside the slave cylinder. Link to comment Share on other sites More sharing options...
