tg1963 Posted January 29, 2014 Report Share Posted January 29, 2014 after replacing my battery,i lost climate control,traction control,heated seats,and weather control on shifter. can i restore using dice vitas? Link to comment Share on other sites More sharing options...
cupdriver91 Posted January 29, 2014 Report Share Posted January 29, 2014 First It would be nice to know what car you are asking about. sorry my mistake I see your car type Link to comment Share on other sites More sharing options...
cupdriver91 Posted January 29, 2014 Report Share Posted January 29, 2014 You shouldn't have lost any of that just changing the battery something else in causing your problem. Link to comment Share on other sites More sharing options...
tg1963 Posted January 29, 2014 Author Report Share Posted January 29, 2014 I was told by a dealer that the software needs to be reloaded and updated. Link to comment Share on other sites More sharing options...
Matty Moo Posted January 29, 2014 Report Share Posted January 29, 2014 Check the power to fuse 8 and 9. You might have a goofy relay on the CEM. Read the codes with Vida and post a screenshot here. Link to comment Share on other sites More sharing options...
tg1963 Posted January 29, 2014 Author Report Share Posted January 29, 2014 Thanks will try...... Link to comment Share on other sites More sharing options...
FCP Euro Posted January 30, 2014 Report Share Posted January 30, 2014 +1 I have replaced my battery on all my Volvos and never had this issue. Even on my S60R. Something else must have happened or at the very least, something shorted out and erased the software, which would be very odd. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 31, 2014 Report Share Posted January 31, 2014 Sounds like the low side of the network failed to start. The easiest thing you can do is perform a hard reset. Remove the negative battery cable and hold it to the positive cable/terminal for about one minute. Re-connect and see if that gets things moving again. Link to comment Share on other sites More sharing options...
limzinfo Posted January 31, 2014 Report Share Posted January 31, 2014 I was told by a dealer that the software needs to be reloaded and updated. That could be the only solution. What ridiculous is that not just only the labor costs but also the software (fireware) costs. Link to comment Share on other sites More sharing options...
tg1963 Posted January 31, 2014 Author Report Share Posted January 31, 2014 thanks for all the advise..... Link to comment Share on other sites More sharing options...
oragex Posted February 2, 2014 Report Share Posted February 2, 2014 I've read that a voltage surge might blow electrical components(?) and that it's recommended to set the key to II before reconnecting the battery. Link to comment Share on other sites More sharing options...
