mattsk8 Posted February 12, 2014 Report Share Posted February 12, 2014 Just thought I'd ask before I bend a rod. I recently replaced my TCV, CBV, fresh air pipe and put a RIP kit on. Everything was good until this morning. At the most random moment, I stepped on the accelerator (not floored at all, prob more like just over half throttle) and it boosted to 24psi all of a sudden, then kicked back down and hasn't done it since. I've had these parts on for a couple days now and this is the first time its done this. I've floored it a few times and it doesn't go beyond about 17-18psi normally; but now I'm very nervous about bending a rod if this happens again. Suggestions?? Link to comment Share on other sites More sharing options...
NEU Posted February 12, 2014 Report Share Posted February 12, 2014 The ECU take about 20mile to update it's self relearn a new upgrade. Did you reset the ECU when you bolted everything up? I get spikes of 24psi at WOT sometimes on my 18psi tune. Link to comment Share on other sites More sharing options...
S70-R Posted February 12, 2014 Report Share Posted February 12, 2014 With the new CBV, fresh intake pipe and rip kit you are likely able to get and hold higher boost levels. What boost are you running and what peak boost did you have before? How cold was in the morning? I don’t know but if that was only one time probably the actuator, for some reason (something a little frozen or stuck), didn’t open the WG flapper in the appropriate time. Link to comment Share on other sites More sharing options...
mattsk8 Posted February 12, 2014 Author Report Share Posted February 12, 2014 The ECU take about 20mile to update it's self relearn a new upgrade. Did you reset the ECU when you bolted everything up? I get spikes of 24psi at WOT sometimes on my 18psi tune. I unhooked the battery for about 10 hours while I did the install. What I didn't do, because the roads were so bad, was do the relearn process the way ARD spells it out. I couldn't really do any medium or hard pulls simply because the roads were completely covered in snow. Maybe I'll unhook the battery and do the relearn the proper way. So far I've actually driven more like 200 miles since I did everything. Glad to hear you get an occasional spike, gives a bit of confidence. Are your internals stock? With the new CBV, fresh intake pipe and rip kit you are likely able to get and hold higher boost levels. What boost are you running and what peak boost did you have before? How cold was in the morning? I don’t know but if that was only one time probably the actuator, for some reason (something a little frozen or stuck), didn’t open the WG flapper in the appropriate time. It was very cold this morning, -10 according the car. The car normally runs 18psi max. Link to comment Share on other sites More sharing options...
S70-R Posted February 12, 2014 Report Share Posted February 12, 2014 It was very cold this morning, -10 according the car. The car normally runs 18psi max. The time you got the spike was the first half throttle pull of the morning? The car was already fully warmed up? Probably the cold really had something to do with it. Something related with the actuator that was frozen or stuck due to the cold conditions. Also remember that cold air = more dense air. Link to comment Share on other sites More sharing options...
NEU Posted February 12, 2014 Report Share Posted February 12, 2014 Yep I'm stock '00R block and 19t. With the ME7 we don't have to worry as much as with the older cars, ME7 is smart enough to dial back the boost if everything is working properly. And you mostly have to worry at low RPM with boost spikes for bending rods. Link to comment Share on other sites More sharing options...
mattsk8 Posted February 12, 2014 Author Report Share Posted February 12, 2014 The time you got the spike was the first half throttle pull of the morning? The car was already fully warmed up? Probably the cold really had something to do with it. Something related with the actuator that was frozen or stuck due to the cold conditions. Also remember that cold air = more dense air. The engine was fully warmed up, I was already about 15 miles into my trip to work. Yep I'm stock '00R block and 19t. With the ME7 we don't have to worry as much as with the older cars, ME7 is smart enough to dial back the boost if everything is working properly. And you mostly have to worry at low RPM with boost spikes for bending rods. That's why it made me nervous, I was probably only at about ~3500RPM when this happened. But as fast as it spiked, it came down quickly too. Link to comment Share on other sites More sharing options...
cgally Posted February 12, 2014 Report Share Posted February 12, 2014 Are you sure the TCV was installed correctly? Link to comment Share on other sites More sharing options...
mattsk8 Posted February 13, 2014 Author Report Share Posted February 13, 2014 Are you sure the TCV was installed correctly? For sure its installed correctly. Its perfectly fine and boosts normal all the time, except for the one, random spike. Link to comment Share on other sites More sharing options...
lookforjoe Posted February 13, 2014 Report Share Posted February 13, 2014 You may need to pay attention to what gear you are in. You didn't mention. Going 1/2 throttle in too high a gear will cause rapid boost buildup. This isn't the weather to be going through the learning curve after M66 conversion, for sure. Link to comment Share on other sites More sharing options...
mattsk8 Posted February 13, 2014 Author Report Share Posted February 13, 2014 You may need to pay attention to what gear you are in. You didn't mention. Going 1/2 throttle in too high a gear will cause rapid boost buildup. This isn't the weather to be going through the learning curve after M66 conversion, for sure. Thanks Joe. I was in a higher gear, now I run it up to at least 3500 and make sure I'm in a lower gear on my accelerations. It was actually when I came to a stop sign; I started accelerating from the stop, crossed the intersection and I got to a steep hill. Once I started going up the hill I was probably in too low a gear and the boost spiked. Lesson learned, when I get to this (or any other hill) I'll leave it in a lower gear for the incline. Link to comment Share on other sites More sharing options...
WayAway Posted February 15, 2014 Report Share Posted February 15, 2014 i ran 23psi in my 850R daily for 2 years. never bent a rod and was never easy on the trottle Link to comment Share on other sites More sharing options...
fwdGTP Posted February 16, 2014 Report Share Posted February 16, 2014 i ran 23psi in my 850R daily for 2 years. never bent a rod and was never easy on the trottle Yea, same, at 26+ psi I didn't have some crank case pressure issues from blowby, but it still runs. Link to comment Share on other sites More sharing options...
