SDkid605 Posted February 16, 2014 Report Share Posted February 16, 2014 What temperature thermostat is required for a 2001 Volvo XC70. I have seen different temperatures availeable and am wondering if there is a better choice according to climate or what. Thanks Link to comment Share on other sites More sharing options...
cupdriver91 Posted February 16, 2014 Report Share Posted February 16, 2014 Don't know where you are located, but if it is a cold climate choose a hotter temperature rating,if hot choose a colder rated one Link to comment Share on other sites More sharing options...
Keaton85 Posted February 16, 2014 Report Share Posted February 16, 2014 Haha why? Outside tempature has nothing to do with it. Your engine will run at a set tempature, it doesn't care if it's -30 or 95 degrees! As long as the cooling system is working it will regulate internal temp just the same. I believe stock was 87C but then Volvo switch to 90C for everything. I like running at 90C personally... Either will be fine. Link to comment Share on other sites More sharing options...
cupdriver91 Posted February 17, 2014 Report Share Posted February 17, 2014 Haha why? Outside tempature has nothing to do with it. Your engine will run at a set tempature, it doesn't care if it's -30 or 95 degrees! As long as the cooling system is working it will regulate internal temp just the same. I believe stock was 87C but then Volvo switch to 90C for everything. I like running at 90C personally... Either will be fine. It doesn't matter to the car but if it's -30c outside I want the warmest air I can in the car.So it does matter. Link to comment Share on other sites More sharing options...
Keaton85 Posted February 17, 2014 Report Share Posted February 17, 2014 5.4degrees difference, I really don't think you will notice that much. But I could be wrong. Link to comment Share on other sites More sharing options...
