mattwebb502 Posted August 2, 2014 Report Share Posted August 2, 2014 I was guessing blue paper shop towel or remnants of a rubber glove. When it comes to your bottom end, cleanliness is next to godliness. I've seen broken plastic bits from a baffle in a VW 1.8 8 valve do this before... No need for the prize. If we ever cross paths, buy me a beer. Second round is on me. Edit: and I bet you forgot the piece that you stuffed into the turbo drain at the block... I've seen a lot of pictures of people with some blue paper towel stuffed down in there, and I've always thought "they'll never see that if they put the drain on from below" Link to comment Share on other sites More sharing options...
clintonpriddle Posted August 3, 2014 Report Share Posted August 3, 2014 Great to hear! Although we haven't met, I have followed your build and really felt for you when I read about your oil pressure issues. Link to comment Share on other sites More sharing options...
survolvo Posted August 3, 2014 Report Share Posted August 3, 2014 I forgot to take the shop towels out of the intake holes after doing a PCV before. Had to spin the crank and fish the pieces out of the valves from the spark plug holes and intake holes. Glad you didn't give up and got it going. Link to comment Share on other sites More sharing options...
lookforjoe Posted August 3, 2014 Report Share Posted August 3, 2014 Good news! I forgot to remove the foam/paper padding that was stuffed in my compressor outlet when I first installed the 6262bb... Link to comment Share on other sites More sharing options...
mattwebb502 Posted August 3, 2014 Report Share Posted August 3, 2014 While we're talking about foreign objects When I was a kid I jammed apples from our tree into my mom's escort wagon tailpipe... she was not too pleased when she got dizzy from the CO and then found out. Condom (with a hole cut) on dad's early 80's Chevy work van tailpipe was a hit with the neighbor kids when he drove off and it inflated to the size of a large watermelon Haha. Seriously glad for you though. You dodged a bullet. Link to comment Share on other sites More sharing options...
fwdGTP Posted August 3, 2014 Report Share Posted August 3, 2014 So glad to hear that's what it is, that seems to happen a lot lol. Link to comment Share on other sites More sharing options...
FINN Posted August 3, 2014 Report Share Posted August 3, 2014 Awwsome news! Very happy for you man. Link to comment Share on other sites More sharing options...
boxpin Posted August 6, 2014 Author Report Share Posted August 6, 2014 Oil Pump Talk: I ran across this description of the different Oil Pumps. Is there a physical/visual way to tell which pump is which? The below is talking about the B5234T Engine: The high power output has placed greater demands on the engine lubricating system and cooling. The following have been changed in comparison to the other 5-cylinder engines:-The oil pump capacity has been increased by a wider pump wheel and a modified profile.-The relief valve has a more rigid spring and opens at 6 bars of pressure (B5254's opens at 5 bar). I want to make sure I am running the higher capacity pump but unfortunately I dont know what I grabbed when I assembled the car. Does anyone have access to these two pumps and can say whether they are visually different from the outside casting? Link to comment Share on other sites More sharing options...
boxpin Posted August 8, 2014 Author Report Share Posted August 8, 2014 Back on the road and purring like a kitten. Link to comment Share on other sites More sharing options...
FINN Posted August 8, 2014 Report Share Posted August 8, 2014 Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted August 8, 2014 Report Share Posted August 8, 2014 AW-tresome!!! That make two guys and a girl judging by the size of the hands!!! Glad the car is OK!!! Link to comment Share on other sites More sharing options...
fwdGTP Posted August 8, 2014 Report Share Posted August 8, 2014 Yeeeeeeeee Link to comment Share on other sites More sharing options...
Commander Riker Posted August 9, 2014 Report Share Posted August 9, 2014 Link to comment Share on other sites More sharing options...
boxpin Posted August 9, 2014 Author Report Share Posted August 9, 2014 Swapped out the plugs today, trying out the Bosch F5DPOR's. The little suckers are expensive. Did a compression test while I was at it...180 across the board. Retapped the meth jet and then went out for a stroll to get Aaron some more logs. Found out quickly that I need better brakes. Hard to bring that thing back down to a stop. Link to comment Share on other sites More sharing options...
Kevin. Posted August 9, 2014 Report Share Posted August 9, 2014 stock brakes or 302's? Link to comment Share on other sites More sharing options...
