FINN Posted March 19, 2014 Report Share Posted March 19, 2014 Wanted to see the consensus here. I used OEM gaskets and applied them on wet. They ended up leaking. So I'm thinking of putting them on completely dry. Link to comment Share on other sites More sharing options...
s_moneh Posted March 19, 2014 Report Share Posted March 19, 2014 applied them on wet? is this somthing new? i've never heard anyone putting on gaskets wet... Link to comment Share on other sites More sharing options...
Rsterns Posted March 20, 2014 Report Share Posted March 20, 2014 I used a bit of high tack gasket sealer no problems encountered. Link to comment Share on other sites More sharing options...
mattwebb502 Posted March 21, 2014 Report Share Posted March 21, 2014 not meaning to hijack, but am I correct in understanding that Volvo actually used _GASKETS_ for the squirters? I had been picturing never-need-to-be-serviced banjos and copper washers or a press fit into the casting. Is this something I should be concerned with replacing while I have everything apart? Anybody know the part number? EDIT: and how does one ever know that they are leaking? We are talking about the bore/piston squirters, correct? Link to comment Share on other sites More sharing options...
s_moneh Posted March 21, 2014 Report Share Posted March 21, 2014 it only applies to non RN motors. where u can access the squirters from the outside. if you have the entire motor apart u can do it but if ur not boring the cylinders then they dont have to come out and u dont really have to replace them Link to comment Share on other sites More sharing options...
FINN Posted March 21, 2014 Author Report Share Posted March 21, 2014 Pic for reference. Link to comment Share on other sites More sharing options...
Falcone Posted March 21, 2014 Report Share Posted March 21, 2014 I don't use the gaskets. I use the cam cover pink sh!t. Never had a problem. 5 years on mine, and two others i've build are going on 3ish. Link to comment Share on other sites More sharing options...
FINN Posted March 22, 2014 Author Report Share Posted March 22, 2014 Well that's interesting. Standard light coating? Link to comment Share on other sites More sharing options...
Falcone Posted March 22, 2014 Report Share Posted March 22, 2014 Yep, just like you're sealing the cam cover Link to comment Share on other sites More sharing options...
