Yellow95 Posted April 9, 2014 Report Share Posted April 9, 2014 So I pulled a 901, center speaker, dolby box and speaker connector out of a JY C70. Hot home and realized that I must have left something, WHere does the center speaker wire plug into? I dot see where it plugs into the back if the 901. I obviously left some kind of harness. Anyone got a pic of whats needed? Gary Link to comment Share on other sites More sharing options...
burnout8488 Posted April 9, 2014 Report Share Posted April 9, 2014 There's a green plug on the back of the 901 it should go into. The harness snakes down the dashpad to the left of the vents I think. Made my own harness awhile back: Green is radio side, white is speaker side. Link to comment Share on other sites More sharing options...
Yellow95 Posted April 9, 2014 Author Report Share Posted April 9, 2014 There's a green plug on the back of the 901 it should go into. The harness snakes down the dashpad to the left of the vents I think. Made my own harness awhile back: Green is radio side, white is speaker side. Looks like I will need to make my own also. Can you tell me what you did? Link to comment Share on other sites More sharing options...
101 Posted April 9, 2014 Report Share Posted April 9, 2014 Here's pictures of everything and more than you would care to know ... http://www.___.com/forums/viewtopic.php?f=33&t=54342&start=14 Link to comment Share on other sites More sharing options...
burnout8488 Posted April 9, 2014 Report Share Posted April 9, 2014 Wasn't easy, I had to depin and repin the green connector to match the 901's outputs. I believe I got the green one out of the box that goes on top of the instrument cluster. The white one was from a tweeter harness I think, but the white connectors vary a bit in their orientation. (The position of the raised slot) Link to comment Share on other sites More sharing options...
Yellow95 Posted April 28, 2014 Author Report Share Posted April 28, 2014 OK, went back and got the plug out of the C70 but the green plug had four wires coming out of it. 2 that went to the speaker but I have no idea where the other two went? Any ideas guys? Link to comment Share on other sites More sharing options...
101 Posted April 29, 2014 Report Share Posted April 29, 2014 I've never skinned back my harness, but the center speaker only uses the two wires. If you have two other wires in that harness - they are not needed or used. Link to comment Share on other sites More sharing options...
BEJinFBK Posted April 30, 2014 Report Share Posted April 30, 2014 IIRC, the other leads are used in C70's only. Link to comment Share on other sites More sharing options...
