Zulu Posted February 10, 2005 Report Share Posted February 10, 2005 Mounting a Apex'i Turbo timer on 98 S70 T5...I'd rather install it with a friend than have shop do it (we've got the experience). But we need to know which wires we need to splice on the ignition harness to what colors? Do we have to use the ground wire on the ECU connection, or can any be used? Does anybody have the location of the ignition wire, O2, and ground? Thanks. Link to comment Share on other sites More sharing options...
ToxicLemonade Posted February 10, 2005 Report Share Posted February 10, 2005 i believe there is a pinned thread on how to install a turbo timer. Link to comment Share on other sites More sharing options...
550 Posted February 10, 2005 Report Share Posted February 10, 2005 Use any ground. Read the post on TT setup. from the tt --> carignition --> blue/red traceraccessory --> yellow/violet tracer12vConstant --> red (big one) ground --> any ground on the carOk the ignition wire is the blue/red tracer wire that is by the knee bolster. There will be a group of wires with black tape around it shooting up toawrds the steering wheel, look for the blue/red wire there.also there is the topic for TT wiring posted at the top of the performance board.The 02 sensor is hooked onto the downpipe. Link to comment Share on other sites More sharing options...
Zulu Posted February 11, 2005 Author Report Share Posted February 11, 2005 Thanks 550. >_< I knew about the pinned thread all along but my friend asked for the ECU pin-out and I completely forgot about the thread :X Link to comment Share on other sites More sharing options...
550 Posted February 11, 2005 Report Share Posted February 11, 2005 Its cool, I hope you get it to work alright I'm still having some minor issues with mine. But I will figure it out eventually Link to comment Share on other sites More sharing options...
volvo850r Posted February 11, 2005 Report Share Posted February 11, 2005 Dont even bother hooking up the o2 wire since you will not recieve correct readings. We use lambda system which sends different voltage. Link to comment Share on other sites More sharing options...
Guest Guest Posted February 12, 2005 Report Share Posted February 12, 2005 Dont even bother hooking up the o2 wire since you will not recieve correct readings. We use lambda system which sends different voltage.← so the A/F R reading I get will be completely off? Link to comment Share on other sites More sharing options...
Guest Guest Posted February 12, 2005 Report Share Posted February 12, 2005 doh it's Zulu Link to comment Share on other sites More sharing options...
