lookforjoe Posted July 9, 2015 Report Share Posted July 9, 2015 Nice!Is the small intermediate can to allow for drainage of condensate? I set mine up that way. Makes sense that the drain back is happier above oil level :) Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted July 11, 2015 Author Report Share Posted July 11, 2015 4 Quote Link to comment Share on other sites More sharing options...
Stefan Mohammed Posted July 12, 2015 Report Share Posted July 12, 2015 (edited) Diesel block and s60r head and hx60 e85 fuel. Still 200hp in pocket when boost will be turned to 3.0bar.Now only 2.2bar.Need more info on this... this is insane!!! Actually needs a full thread dedicated to it!!! Edited July 12, 2015 by Stefan Mohammed Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted July 12, 2015 Author Report Share Posted July 12, 2015 0-100km/h 8.8s100-200km/h 6.9s200-300km/h 8.8s335km/h @ 1609m 1 Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted July 12, 2015 Author Report Share Posted July 12, 2015 Quote Link to comment Share on other sites More sharing options...
quiksilver Posted July 13, 2015 Report Share Posted July 13, 2015 Extremely impressive.Looks like some aero work needs to be done though. That lip doesn't look overly attached on the driver's side and the hood has lifted about an inch at the front?How stable is the 855 at those speeds? Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted July 14, 2015 Author Report Share Posted July 14, 2015 855 was good to drive. Yesterday i installed my engine and before firing it up put some coolant in system. Well coolant leaked out from block cracks outside under intake manifold.Now engine removed and will make new darton engine this winter and but car in winter storage. This is motorsport... Quote Link to comment Share on other sites More sharing options...
NitroX5 Posted July 14, 2015 Report Share Posted July 14, 2015 Happened with me too Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted July 14, 2015 Author Report Share Posted July 14, 2015 Do you know what caused yours? Did you first blow headgasket? Quote Link to comment Share on other sites More sharing options...
Simply Volvo Posted July 14, 2015 Report Share Posted July 14, 2015 Such a shame, sorry to hear that Marko I know you'll get it up and running though again, stronger and faster than ever. Looking forward to future results.Will you have to shave the head 0.1mm now? Im assuming you can reuse the pyramid rings, but will need a new modified composite head gasket?I tried emailing ProEngines, but they never responded to me.~Matt Quote Link to comment Share on other sites More sharing options...
NitroX5 Posted July 14, 2015 Report Share Posted July 14, 2015 Nono, its not performance related.. It has to be caused by frozen coolant :SIt was a 2.0 V70R junkyard block, what I fully rebuilt. Rebored to 83mm, shimmed, ported headt, etc...I have never seen this before so I wasn't prepared to check the block side for cracks :SI didn't notice that 1.5cm crack on the block, also when I torqued the head there was a loud snap sound. Later it tuned out that was the moment when the harline crack expanded.After the hard work on that engine and 20 hours of installation on that day, everything ready to go... it was a pain to see coolant coming out on the bottom. Tried to weld it wihout success. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted July 14, 2015 Author Report Share Posted July 14, 2015 My engine was now with completely stock headgasket. We havent yet tested those pyramid rings with success but maybe later friend will test.NitroX5: My block did same loud snap sound when head was torqued down. Friend engine did same thing and same sound. Now we know...Our blocks both had headgasket failure first and then rebuild and cracked from intake side. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 15, 2015 Report Share Posted July 15, 2015 Sorry to hear it.Make sure you take pics of the rebuild / darton install Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted July 29, 2015 Author Report Share Posted July 29, 2015 (edited) Goal is to get engine ready with 81mm Darton MID Sleeves for 2016 summer. I will take pictures when i get those bad boys. This is old picture before i but engine in and took it out. Just for motivation purpose. Edited July 29, 2015 by VulvaS40T4 3 Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted August 1, 2015 Author Report Share Posted August 1, 2015 Ordered fuel cooler to keep more constant afr readings. http://www.summitracing.com/int/parts/der-13313/overview/ Quote Link to comment Share on other sites More sharing options...
