laird Posted June 28, 2014 Report Share Posted June 28, 2014 It's a runway for crying out loud. He could probably coast to a stop. Quote Link to comment Share on other sites More sharing options...
theForgottenone Posted June 28, 2014 Report Share Posted June 28, 2014 It's a runway for crying out loud. He could probably coast to a stop. He don't drive on runway 365 days a year. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted June 28, 2014 Author Report Share Posted June 28, 2014 (edited) He don't drive on runway 365 days a year. Yes 364 days on street and 1 day on airfield. BUT like i said i dont drive over 150mph on street and from that speed stock brakes are even better. Stock T4 200hp from factory hits maximum 146mph maximum speed by the way. Edited June 28, 2014 by VulvaS40T4 Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted June 29, 2014 Author Report Share Posted June 29, 2014 Sleeper. https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xap1/t1.0-9/10351835_642781172465967_7331247007140033582_n.jpghttps://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xpa1/v/t1.0-9/10505445_642781202465964_1759057695120832393_n.jpg?oh=5740b34cf1be46011e8184643a5da7ee&oe=541C75A4&__gda__=1410470428_4e4da3c44d33f844e7b1c4352ca14689 Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted August 14, 2014 Author Report Share Posted August 14, 2014 New modded oilpan. https://scontent-b-ams.xx.fbcdn.net/hphotos-xfp1/l/t1.0-9/10599194_665918240152260_7208091013601563490_n.jpg Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted August 15, 2014 Report Share Posted August 15, 2014 Revising the breather system, or adding an additional vent? Quote Link to comment Share on other sites More sharing options...
Simply Volvo Posted August 15, 2014 Report Share Posted August 15, 2014 Revising the breather system, or adding an additional vent? Or possibly a new oil drain. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted August 15, 2014 Author Report Share Posted August 15, 2014 Or possibly a new oil drain. Yes it will be both. Extra oil drain which works also as a breather. There will be also new aluminium 1.5liter breather box to stock place, but that later. Breathing system is okay with s60r box to 0-280km/h acceleration and after 7000rpm on 5.gear breathing system is pushing little bit of oil out so thats why improvements are required. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted August 15, 2014 Report Share Posted August 15, 2014 Yes it will be both. Extra oil drain which works also as a breather. There will be also new aluminium 1.5liter breather box to stock place, but that later. Breathing system is okay with s60r box to 0-280km/h acceleration and after 7000rpm on 5.gear breathing system is pushing little bit of oil out so thats why improvements are required. If it's going to be for drain back, it really needs to be below the level of the oil, that's why the stock one goes to the bottom of the oil pan - to prevent any potential CC pressure from inhibiting drain back.... Have you tested a drain port in this location previously? Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted August 15, 2014 Author Report Share Posted August 15, 2014 Yes friend uses same system and it works great. It works as a extra drain and extra breather. So stock drain is also used. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted August 17, 2014 Author Report Share Posted August 17, 2014 Measured car weight today and it was with 1/2 tank e85 (30liters) and without driver 1360kg (3000lbs). Quote Link to comment Share on other sites More sharing options...
theForgottenone Posted August 17, 2014 Report Share Posted August 17, 2014 More weight reduction needed. Stock phase 2 is 2800lbs from factory. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted August 17, 2014 Author Report Share Posted August 17, 2014 I dont have any weight reduction! I have 12" DLS subwoofer in my trunk also. 2 Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted August 23, 2014 Author Report Share Posted August 23, 2014 (edited) New wastegate Turbosmart Comp-gate 40mm HP. Now boost stays same on every gear. With only wastegate spring baseboost eather 2.5bar (35psi) or 2.8bar (40psi). http://www.turbosmartdirect.com/Product-Categories/High-Pressure-Wastegates/WG40-Compgate-40mm-7-PSI-BLUE_3.html Edited August 23, 2014 by VulvaS40T4 Quote Link to comment Share on other sites More sharing options...
ovlovturbo Posted August 24, 2014 Report Share Posted August 24, 2014 who has done all the map pining? Quote Link to comment Share on other sites More sharing options...
