Zulu Posted February 11, 2005 Report Share Posted February 11, 2005 Saturday I'm installing the dual-stage MBC from "dawe's devices" (I think name is right). Any suggestions where I should mount the MBC within the engine bay that would be relatively close to the wastegate? Also, suggestions for mounting the switch where it's not obvious/out of sight (driver's side). :D Link to comment Share on other sites More sharing options...
wills Posted February 11, 2005 Report Share Posted February 11, 2005 Here is where I put the Turbox twin MBC. Link to comment Share on other sites More sharing options...
Zulu Posted February 11, 2005 Author Report Share Posted February 11, 2005 o: no image? Link to comment Share on other sites More sharing options...
rdiedrich Posted February 11, 2005 Report Share Posted February 11, 2005 I mounted the same MBC on the engine torque bracket, and it's close to the firewall ground. A couple of zip ties will keep it there.Drill a hole in one of the blank switch covers and you've got the perfect spot.Now I want to reverse the operation of the unit so the high boost is on when the switch is lit. Link to comment Share on other sites More sharing options...
Guest Guest Posted February 11, 2005 Report Share Posted February 11, 2005 When you figure out how to reverse the operation of the unit, tell me. Link to comment Share on other sites More sharing options...
Guest Guest Posted February 11, 2005 Report Share Posted February 11, 2005 This is Zulu :D Link to comment Share on other sites More sharing options...
550 Posted February 11, 2005 Report Share Posted February 11, 2005 Hey rd, does your switch have two or three prongs?? Link to comment Share on other sites More sharing options...
Zulu Posted February 11, 2005 Author Report Share Posted February 11, 2005 3...Joe said he just reversed the wires when he had this MBC? Link to comment Share on other sites More sharing options...
550 Posted February 11, 2005 Report Share Posted February 11, 2005 Yeah all you shoudl have to do is reverse the wires, sometimes with a momentary switch you can have it so when you push it, it is closed circuit, or when you are not pushing it it is closed.So some are different, but switching the wires around should work. Link to comment Share on other sites More sharing options...
