Phil94850 Posted June 9, 2014 Report Share Posted June 9, 2014 Ive been chasing down a problem I cant figure out. When driving my car it feels like the steering is kinda loose. I have a little play and it doesn't feel tight and responsive as it should. Ive replace- struts, strut mounts, cv axles, both lower control arms, upper engine mount, drivers side wheel hub, inner and outer tie rods. the only other issues ive found is the front and rear lower engine mounts need replacing and of course the worst would be the steering rack. The car has 205k on it. any ideas ? can my mounts cause the loose feeling ? Link to comment Share on other sites More sharing options...
hotpantslovebug Posted June 9, 2014 Report Share Posted June 9, 2014 Level and condition of power steering fluid? Even a flush and refill might help. Link to comment Share on other sites More sharing options...
Kevin. Posted June 9, 2014 Report Share Posted June 9, 2014 steering rack, subframe bushings, engine mounts Link to comment Share on other sites More sharing options...
Phil94850 Posted June 9, 2014 Author Report Share Posted June 9, 2014 took to a friend that works at a Volvo shop and he said he can see the rack arm on the drivers side moving up and down so id say that's my problem... when the subframe bushings go bad, how can you tell ? Link to comment Share on other sites More sharing options...
Kevin. Posted June 9, 2014 Report Share Posted June 9, 2014 they pop at low speeds, suspension feels squishy. Given you have 200k+ miles it's probably time to do them and considering you need to replace the rack it's the perfect time! Get the Kaphlenkhe ones Link to comment Share on other sites More sharing options...
Phil94850 Posted June 9, 2014 Author Report Share Posted June 9, 2014 thanks kevin Link to comment Share on other sites More sharing options...
MC92 Posted June 10, 2014 Report Share Posted June 10, 2014 Had my steering rack replaced last summer, tightens the steering a little bit (or at least what it feels like to me). Link to comment Share on other sites More sharing options...
Mybox855 Posted June 16, 2014 Report Share Posted June 16, 2014 Replace your sway bar end links. I just swapped mine out because my steering felt slack and loose and this helped out a bunch. Link to comment Share on other sites More sharing options...
broken041 Posted June 17, 2014 Report Share Posted June 17, 2014 I encountered a rear subframe mount being worn. At highway speeds the car felt nervous. Darted with minimal driver input. Didn't always track perfectly. Just a thought. Link to comment Share on other sites More sharing options...
Phil94850 Posted June 18, 2014 Author Report Share Posted June 18, 2014 Im planning on putting new sway bar links and replacing the rack and that hopefully will take care of it.. Link to comment Share on other sites More sharing options...
