Brad850 Posted July 16, 2014 Author Report Share Posted July 16, 2014 Thanks guys. Now the question is which do I choose due to the loose wastegate flapper I may be looking too much into this lol. Link to comment Share on other sites More sharing options...
Brad850 Posted July 17, 2014 Author Report Share Posted July 17, 2014 Pounded on the rivet type clip that holds the flapper circle and ended up reducing excess play. Now the arm is more effective in keeping a tighter seal because it has less room to pivot. Hard to explain but it worked! Link to comment Share on other sites More sharing options...
mattwebb502 Posted July 17, 2014 Report Share Posted July 17, 2014 pictures? sounds like you tapped on the flapper arm pivot point from the outside of the housing? I've run across several posts about doing this for sticky/binding/non closing waste gate flappers on older td04h turbos. Link to comment Share on other sites More sharing options...
Brad850 Posted July 17, 2014 Author Report Share Posted July 17, 2014 No, I did it on the inside. It's not pretty but...by beating the shit out of it, I reduced the empty space between the small circle and arm. Now there's more leverage and less room for the arm to pivot. Link to comment Share on other sites More sharing options...
fwdGTP Posted July 17, 2014 Report Share Posted July 17, 2014 Sounds like it should work Link to comment Share on other sites More sharing options...
lookforjoe Posted July 17, 2014 Report Share Posted July 17, 2014 No, I did it on the inside. It's not pretty but...by beating the shit out of it, I reduced the empty space between the small circle and arm. Now there's more leverage and less room for the arm to pivot. There should be a small amount of play to allow the flapper to seat properly - you didn't remove all the slack I presume? Link to comment Share on other sites More sharing options...
Brad850 Posted July 17, 2014 Author Report Share Posted July 17, 2014 No sir. I'd say it has just as much as the other exhaust housing now. Link to comment Share on other sites More sharing options...
mattwebb502 Posted July 18, 2014 Report Share Posted July 18, 2014 this evening I yanked my 6-189-13302 "KN2" housing and replaced with the 189-13202-7 "760" 7CM housing that I received with my Volvo supplied 19t below are pics; new and shiny item is the 7cm EDIT: Initial impressions show no change in performance/behavior/etc on my 2.3l w/auto trans. Link to comment Share on other sites More sharing options...
