fenwick253 Posted July 28, 2014 Report Share Posted July 28, 2014 I have a 2000 V70R and my bevel gear has eaten itself. I've split the case and noticed that most of the pinion gear's teeth are knocked off. To my surprise, the ring/main gear seems to not have eroded or missing teeth. I have a lead on another 2000 x70 angle gear with worn input spline wear, and I'm wondering if it would be a simple enough fix to swap my ring/main gear with the donor? Should I be concerned with mating issues of different angle gears (from wear), or preload/backlash issues, etc.? Thanks, Scott Link to comment Share on other sites More sharing options...
cupdriver91 Posted July 28, 2014 Report Share Posted July 28, 2014 I would be they should be installed as a set.IMO Link to comment Share on other sites More sharing options...
fenwick253 Posted July 29, 2014 Author Report Share Posted July 29, 2014 I would be they should be installed as a set.IMO My thoughts also. I would think each angle gear would have equal wear between the gears in their respected pairs, thus pairing others may lead to differences in degree of wear on the gear teeth, resulting in another failure. Link to comment Share on other sites More sharing options...
sjmcarz Posted July 29, 2014 Report Share Posted July 29, 2014 ^ Correct. Never mixed used ring and pinion gears, they must be a matched set only. Link to comment Share on other sites More sharing options...
