Brad850 Posted August 27, 2014 Report Share Posted August 27, 2014 Say you have a considerable exhaust leak before the o2 sensor (lets assume the exhaust flange welds are leaking). Will this cause you to run rich or lean? Link to comment Share on other sites More sharing options...
mattwebb502 Posted August 28, 2014 Report Share Posted August 28, 2014 It can allow outside air into the exhaust stream and contaminate it, causing a lean read on the o2, which will result in a rich running condition. Link to comment Share on other sites More sharing options...
Brad850 Posted August 28, 2014 Author Report Share Posted August 28, 2014 Even if you can feel it pushing exhaust gas out? Link to comment Share on other sites More sharing options...
mojojo Posted August 28, 2014 Report Share Posted August 28, 2014 An exhaust leak is going to result in a lean condition. Engine management will attempt to correct the situation by adding fuel, but remember the ems has a small window to try and 'tune' this out. Link to comment Share on other sites More sharing options...
