850T5M Posted August 29, 2014 Report Share Posted August 29, 2014 So a little while ago my car started stalling after a hot start. It happened once or twice a month, now it does it all the time and I cannot start the car when it is hot. Basically the engine turns over, it starts, then 0.5-1 second later it stalls. If I pull out the MAF sensor wire (making the car go into open loop) it will start no problem. If i plug the MAF back, it stalls. I just bought a brand new Bosche MAF assuming that was the problem, but it pursists! I guess pulling any sensor off will cause it to start, as it starts reading values off the ECU... What can I look for? IAC? Coolant Temp Sensor? Is there a way of testing these things? Link to comment Share on other sites More sharing options...
erikv11 Posted August 29, 2014 Report Share Posted August 29, 2014 Maybe the MAF connector is bad? Link to comment Share on other sites More sharing options...
