boxpin Posted January 14, 2015 Report Share Posted January 14, 2015 Todays events. Link to comment Share on other sites More sharing options...
gilber33 Posted January 14, 2015 Report Share Posted January 14, 2015 Geezus man. You apparently need to get a larger net to catch more breaks, because you haven't caught any.... dad jokes. Link to comment Share on other sites More sharing options...
mattwebb502 Posted January 14, 2015 Report Share Posted January 14, 2015 sh!t Link to comment Share on other sites More sharing options...
Piston Slapper Posted January 14, 2015 Report Share Posted January 14, 2015 Damn man, that sucks. Link to comment Share on other sites More sharing options...
boxpin Posted January 14, 2015 Author Report Share Posted January 14, 2015 That is oil and happens now and then. Seems low RPMs in first or second gear trigger it more than higher RPMs. I am not losing any coolant and nothing in the oil. It goes away then comes back. More so on right turns. I think its the seal on the turbo. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 14, 2015 Report Share Posted January 14, 2015 Did you try venting the crankcase from the dipstick? CC system can easily push oil past the turbo oil control ring at idle if there is a restriction. Even if it is the turbo, the drain tube sizing can be a problem, and the breather system. Link to comment Share on other sites More sharing options...
boxpin Posted January 14, 2015 Author Report Share Posted January 14, 2015 Did you try venting the crankcase from the dipstick? CC system can easily push oil past the turbo oil control ring at idle if there is a restriction. Even if it is the turbo, the drain tube sizing can be a problem, and the breather system. My breather is a full 1" into a ProVent. Keep in mind that was idling. Even when my rings were cracked it didnt do this. Link to comment Share on other sites More sharing options...
Commander Riker Posted January 14, 2015 Report Share Posted January 14, 2015 Yeah, I'm going to go with turbo seal. Sorry to see it man. It looks exactly like my K24 when it went. Was kinda random at first... then just got more and more frequent, especially at idle. Is it possible any of the bit of cracked rings got to it in the oil? Link to comment Share on other sites More sharing options...
boxpin Posted January 14, 2015 Author Report Share Posted January 14, 2015 Is it possible any of the bit of cracked rings got to it in the oil? Could have been anything really but this is a whole new engine. Link to comment Share on other sites More sharing options...
fwdGTP Posted January 14, 2015 Report Share Posted January 14, 2015 Damn man, that sucks. Hopefully you get it figured out, but I would assume it's turbo related. Link to comment Share on other sites More sharing options...
Chrispy_T Posted January 15, 2015 Report Share Posted January 15, 2015 It's most likely turbo seals. When I burnt up a ring on the exhaust side and, at a different time, pinched the o-ring on the intake side, I had the same symptoms but not quite as much oil burning. Turbo rebuilds are cheap and easy enough. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 15, 2015 Report Share Posted January 15, 2015 Don't buy a cheap rebuild kit. Kamak Dynamic / Kinugawa is usually OK The first thing to check is end play on the turbo. If you have excessive float that would indicate the thrust bearing is also toast, and that can cause the oil control ring seat to wear, which will never seal no matter how many times you replace it. That is exactly what happened with my 20g. Link to comment Share on other sites More sharing options...
Commander Riker Posted January 15, 2015 Report Share Posted January 15, 2015 Those are some damn good pictures, H. Link to comment Share on other sites More sharing options...
