Fudge_Brownie Posted February 21, 2015 Report Share Posted February 21, 2015 as the boost isn't that high - doesn't even leave the white of the stock turbo gauge - and I run 95 ocaten fuelI'm quite certain it doesn't give me 300BHP, because I can't floor it. I'm running a 15G - the ECU is tuned for a 16T. It's the drop-in RICA tune.So it is significantly under target boost? And no Check Engine light set for misfires? Sounds like a large boost leak you haven't found yet. A common one people miss is at the throttle body. The smaller hose running to the IAC develops a crack at the base which will only reveal itself when pressurized. Link to comment Share on other sites More sharing options...
lookforjoe Posted February 21, 2015 Report Share Posted February 21, 2015 If all the ignition components are known good, and although used came from a known good running car, I would agree on checking the IAC/TB hose - it can rupture underneath, and will suck in at idle, and only leak over around 12psi (that was my experience) car will if course go flat at that point. Link to comment Share on other sites More sharing options...
