aharres Posted April 23, 2015 Author Report Share Posted April 23, 2015 Ended up ordering motorsport tech spacers. 16mm front and 4mm rear (to clear the cap) and they convert from 65.1mm to 73.1mm center bore. I guess I'm going to do the stud conversion. Does everyone still recommend the westcoast wheel accessories stud conversion? Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted April 23, 2015 Report Share Posted April 23, 2015 Are you saying that the rear spacer is also a center bore adapter? 4mm isn't thick enough to convert the center bore. I have an extra set of wheel studs if you want them. Link to comment Share on other sites More sharing options...
aharres Posted April 23, 2015 Author Report Share Posted April 23, 2015 Are you saying that the rear spacer is also a center bore adapter? 4mm isn't thick enough to convert the center bore.It is if you're converting to a larger center bore. I'm going 65.1mm to 73.1mm.I was on the phone with one of west coast wheel accessories' retailers and ended up ordering those. They convert to m12x1.5 and are 1.75" in length. Thank you for the offer though. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted April 23, 2015 Report Share Posted April 23, 2015 Yup, you're right. Wasn't thinking there... Link to comment Share on other sites More sharing options...
aharres Posted May 13, 2015 Author Report Share Posted May 13, 2015 Get stud conversion kit off eBay. $20 or so, and converts from 12.75 to 12.5, so much wider range of wheel nuts are available. Makes it much easier when you have to ditch the rotor guide pin. LugNutGuys, I think is the vendor that carries them.I ended up getting west coast wheel accessories studs and nuts through A2I. M12x1.75 to M12x1.5 stud conversion with 1.75" total length. I also got these sweet black lug nuts with a 19mm head. Patiently waiting for my motorsport tech spacers. Link to comment Share on other sites More sharing options...
