gottarollwithit Posted April 5, 2015 Report Share Posted April 5, 2015 Just had the car detailed and now that i've gotten it home it won't start. There's no CEL codes or popped fuses. It's as if this is a carb'd car having a difficult time cold starting. On start up, the fuel pump will spin as it should, but it'll crank endlessly and not fire. After i stomped the throttle pedal, it fired and ran/drove like normal. After i shut it down, then tried to restart, it'd fire up for a moment, then immediately die. Then after a couple more tries, it'd fire and run normally I'd say maybe it's a engine coolant temp sensor, but i'm not getting really bad mileage, no funky smoke, and no codes. Maybe a immobilizer antenna? It's almost as if this has a sticky throttle body, but we just put in a new Xemodex ETM. Thoughts?? Link to comment Share on other sites More sharing options...
