Upgraded Front Motor Mount
Brad850
  • Replies 42
I've been keeping an eye on this thread in case any actual content should appear. Just ordered one of these (as OEM replacement for '99 XC70) and was hoping to learn something interesting.
Should have it on the doorstep tomorrow and will pop it on, the current mount allows the engine to flop around (all other mounts new/OEM). We'll see if it is a cure all...
Neu I believe the pass mount is technically the front mount. Acorns are really left and right.
You should tell that to IPD and FCP and other cause they all list them as Right/Pass. side (USA). Nobody I've seen list the it as front, they list the front as front. ;)
I used Window Weld Poly caulk to fill the gaps and encase it in hard poly. >Here my post from '10 This will transmit a lot of vibration into the car.
And since nobody wanted to look up part # to find the answer, part# 8631702 is the 302 version. If you look at IPD they list the mount they sell are the 288 version, (8631698, 9141257, 9209869 8631698V, 8631698, 9141257, 9209869).
Front of motor vs. front of car, technically neither one is wrong. +1'd for the part number!
