Peace562 Posted April 10, 2015 Report Share Posted April 10, 2015 Hello Everyone, I have a Question regarding the PCV, Turbo, and The Oil Leaks Rssulting from a Bad Vacuum. First off, I bought this 2000 Volvo S40 1.9T with 160k. After about 3 weeks of no Problems. I started to get a Click coming from the Exhaust Cam sprocket and then a Subsequent leak from the respective cam seal. So I went in and replaced the Gear and seal. All be it with a Used Cam gear. After the leak returned I took it in to an Indy Volvo service shop where they told me That Besides the bad seal I had Positive crankcase pressure. They said this pressure was causing oil to get pushed past the seals and getting into the T Belt and Gears which was at risk of slipping and Bending Valves. So After being quoted 2k To do all the work I decided to go the DIY way. So I dismantled the Intake And Got into the breather box I found the ports Not really clogged there was a small amount of Gunk in the bottom port but nothing to the point where air flow could be restricted. I still gave it a good cleaning. Same with the hoses, replaced the breather box. I then went ahead and replaced the cam seal again, huge Pain. After all that I still don't have a Vacuum. Or at Least it's only a Partial Vacuum a rapid intermittent vacuum as Shown in this YouTube Vid I Posted. Link to comment Share on other sites More sharing options...
theForgottenone Posted April 11, 2015 Report Share Posted April 11, 2015 Vacuum leak on some other hose. Did you check the idle control hose from ic to tb? Link to comment Share on other sites More sharing options...
Peace562 Posted April 11, 2015 Author Report Share Posted April 11, 2015 Vacuum leak on some other hose. Did you check the idle control hose from intercooler to tb?Is This The respective hose? If so I tried to blow thru it and couldn't maybe it's clogged ? Link to comment Share on other sites More sharing options...
theForgottenone Posted April 11, 2015 Report Share Posted April 11, 2015 It wasn't that one but I would look at all those to make sure there are no needle /pin size leak. You can get a soapy water solution and spray over them. Turn on the engine and watch I any area get dry up while the rest stay wet. Link to comment Share on other sites More sharing options...
